Can't Remove CPL
Discussion in 'Beyond the Basics' started by decado, Jul 4, 2010.
  1. decado
    decado TPF Noob!
    Sep 24, 2009
    155
    Crystal, MN
    So I put my B+W Kaeseman CPL on my Canon 10-22 lens earlier (didn't even twist it on very hard) and now I can't get it off with all my strength (and I'm pretty strong). What are some methods I can use to remove it that won't damage the lens or the filter?
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    OK - DO NOT waste your money on filter wrenches. They do not work.
    That being said - grip the filter spacing your fingers as evenly as possible.
    Even pressure is what will get it off.
    Just take your time, step away from it for a minute if you have to. Apply even pressure across the entire circumference of the filter and it should come off.
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,479
    15,211
    USA
  4. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    I have seen this happen before, often in cold environments
    take it into a warm room, heat = expands so it will be easier to remove (Y)
    or just try pry it off, leave it for about 5 mins try again, repeat.
  5. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    Have you checked to see if by chance you cross threaded the filter on? It is unusual for a B&W filter to get stuck like this since they are one of the few companies that use brass housings instead of aluminum.
    As others have said, steady even pressure after the thing has come to room temp.
  6. KmH
    Apr 9, 2009
    40,738
    5,588
    Iowa
    Even those rubber like, floppy, flat, gizmos used for taking jar lids off might help.
    The slim filters used for wide angle lenses can be tricky to get on or off.
  7. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,335
    Way up North in Michigan
    Extreme filter wrenching true story:
    [​IMG]
    After this happened, I had a heck of a time getting the busted filter off, because of the way the ring had deformed. I tried everything I could think of from filter wrench to rubber band trick to even pressure with evenly spaced fingers... None of it worked.
    I took it to a mechanic to see if he had any ideas. He used an oil filter wrench with an adjustable rubber strap, much like this:
    [​IMG]
    It did NOT want to come off, even with that, but it had no choice. A few minutes later, after blowing the glass particles out with a rocket blaster, I was screwing on a new filter like nothing had happened.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Ouch!
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Buckster thanks for that. Believe it or not we have the exact same problem here. Except it was an Olympus telephoto which took a tumble and now has a broken filter stuck. I'll consider taking the lens to work and seeing if one of the fitters has a tool for the job.
  10. Infidel
    Infidel TPF Noob!
    May 21, 2010
    490
    22
    Western MA
    Tempted to use some of this:
    [​IMG]
  11. Arkanjel Imaging
    Arkanjel Imaging No longer a newbie, moving up!
    Jun 8, 2009
    1,229
    157
    SW Florida
    I believe that has to go on before things get screwed together. ;) They do make some penetrating "breaking" compounds. Im not sure Id be spraying my precious glass with it though.
    x2 on the wide rubber band. Thats always worked for me in the past. If you somehow cross-threaded the filter its going to be tough.
  12. lvcrtrs
    lvcrtrs TPF Noob!
    Dec 18, 2008
    606
    Pennsylvania
    I keep a rubber band in my bag for this exact purpose. After i got the cpl off with it once i try to not hoss on it too much when I put it on now.
cpl filter removing
