Capture NX 2
Discussion in 'Graphics Programs and Photo Gallery' started by Joel_W, Mar 9, 2012.
  1. Joel_W
    Joel_W TPF Noob!
    Dec 9, 2011
    2,211
    164
    Long Island, New York
    I've been using Nikon's View NX 2, and become quite comfortable editing with it. I'm about ready to move up to the next level. So I downloaded the 30 trial of Adobe's Elements 10, and I did struggle with it at times, never getting that comfortable with it. I'm sure with enough time and effort, I'll get over the hump. But I'm wondering that since I'm so comfortable with View NX 2 if I would be better off going with Catpure NX 2 instead. Any advice would be greatly appreciated.
  2. SCraig
    SCraig Been spending a lot of time on here!
    Nov 12, 2011
    6,315
    2,368
    Nashville, TN
    I've been using Capture NX2 for the past couple of years and really, really like it. Once you become accustomed to it you can do a lot with it.
    Unlike View NX2 most, but not all, edits are non-destructive. Edits are done using "Adjustments", and each "Adjustment" is added to an edit list. If you don't like the result just turn it off or remove it. Shooting RAW with Nikon gear will really get the best out of it since there are a number of corrections that can only be done to RAW files such as lens correction. Some tools such as white balance can also be done to RAW files just by changing from Daylight to Tungsten, for example.
    I bought a book entitled "Nikon Capture NX2" by Mike Hagen (ISBN: 978-0-470-40926-8) that really helped me a lot. Step by step he covered virtually everything NX2 can do and did so in an easily understood manner. I highly recommend it.
    Let me know if you have specific questions.
  3. Joel_W
    Joel_W TPF Noob!
    Dec 9, 2011
    2,211
    164
    Thanks Craig. I certainly. I certainly will. Will be making the move within the next few days.
  4. SCraig
    Nov 12, 2011
    6,315
    2,368
    Nashville, TN
    Forgot to mention, although you probably already know, you can download a 60-day trial of Capture NX2 from Nikon's web site.
  5. Joel_W
    Joel_W TPF Noob!
    Dec 9, 2011
    2,211
    164
    Funny you should mention that. I just did that a little while ago.
  6. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,281
    7,937
    Iowa
    FYI: You can edit ANY jpeg or tiff in C-NX2, and save it as a NEF. That will not make it a raw file, but it will save the image in the same non-destructive manner as raw files.
  7. SCraig
    Nov 12, 2011
    6,315
    2,368
    Nashville, TN
    Correct. I may have given the wrong impression in my original post, but that is exactly correct. However, not being a RAW file you will not be able to use any of the "Camera Settings" options on it (they are similar to the in-camera settings that allow adjustment of white balance, picture control, Active-D Lighting, etc.)
  8. Joel_W
    Joel_W TPF Noob!
    Dec 9, 2011
    2,211
    164
    Been using Capture NX 2.3 for a few weeks now, and I'm starting to get very comfortable with it. Basic Work Flow makes sense, and there are more then enough special features such as Color Points to make this a solid eiditing program.
  9. SCraig
    Nov 12, 2011
    6,315
    2,368
    Nashville, TN
    I agree. Once one becomes accustomed to what it can do and how to do it the software is capable of doing a lot in a very short amount of time. In my opinion it's one of the more under-appreciated editors around.
  10. Joel_W
    Joel_W TPF Noob!
    Dec 9, 2011
    2,211
    164
  11. 480sparky
    Mar 8, 2011
    22,281
    7,937
    Iowa
    Get Mike Hagen's After the Shoot. It is to C-NX2 what Bryan Peterson's Understanding Exposure is to noobs.
    • Like Like x 1
  12. Joel_W
    Joel_W TPF Noob!
    Dec 9, 2011
    2,211
    164
    Thanks 480Sparky. Checking it out right now.
capture nx2 vs viewnx 2
difference between capture nx2 view nx2
difference between view nx2 and capture nx2
difference between view nx2 capture nx2
how does capture nx save multiple versions
nikon view nx2 vs capture nx2
nx view2
view nx2
what is the difference between view nx2 and capture nx2
