Capturing architectural plans
Discussion in 'Beyond the Basics' started by cursor, Nov 30, 2007.
  1. cursor
    cursor TPF Noob!
    Nov 30, 2007
    I'm hoping some of you can offer advice as to how I might effectively capture select portions of architectural plan sets. I regularly receive requests to bid precast work (columns, balustrades, etc) and need to digitally capture only those parts of the plan sets that concern me. My hope is 1) to maintain vertical/horizontal integrity, and 2) to get reasonable contrast between black line-work and the [typically] white background. Architectural drawings can be as large as 34" x 44".
    Once captured, I expect to use Xara Xtreme Pro to highlight, doctor and graphically emphasize the scope of work to be performed.
    While there is no doubt that a large format flatbed scanner would be optimal, I'm hoping to get this reasonably done using a 7.2 megapixel digital camera, accessory lighting, and tripod.
    t h x
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    If this is for professional uses, doing it haphazard with a camera will result in sub-professional results. Is this the view you want to take for your clients to see?
    Purchase the right equipment and write it off as a business expense. Please your clients and have them come back to you again due to the quality and clarity of your work.
    Just MHO.
  3. cursor
    cursor TPF Noob!
    Nov 30, 2007
    Thanks for your input, Jerry.
    While that is what I would like to do (take the quality/professional approach), there's simply no way that my employer would foot the bill for scanner equipment that'll handle 34"x44" printed media.
  4. JerryPH
    Oct 14, 2007
    6,111
    15
    Can you not use a smaller scanner and stitch the parts together?
    How about printing out parts of designs that you need and not the whole project?
  5. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    This must sound like a daft question but, unless you are working somewhere that doesn't use CAD, why can't you use the CAD files?
    Best,
    Helen
  6. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,190
    22
    Hollywood, FLA USA
    1) Ask for set of copies
    2) Make copies at fedex kinkos or the ups store
    3) Ask for PDF file have printed at fedex kinkos or the ups store
  7. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    That Is what I was thinking. I personally use Vectorworks, and you can save a file in just about any format, Vectorworks, Autocad, sketchup, PDF, JPG...etc...
    And with photographing there is now easy way to maintain scale.
    Then I do Know some old school guys that still use their drafting boards and blue-liners.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Well if you can a) keep it flat, b) use a lens with no barrel distortion like a fixed focal length lens, and c) get consistent lighting across the drawing sets then you're in business.
    C will be the real problem. Two flash units fired into umbrellas each placed at 45 degrees off axis from the drawing would be ideal.
  9. Bevel Heaven
    Bevel Heaven TPF Noob!
    Aug 28, 2007
    237
    Pleasant Hill, CALIFORNIA
    suggest you use a nikkor 60mm f2.8 lens, on a tripod, no flash just ambient light [window, skylight etc] piece of clean glass over the plan, 800 iso - voila. This lens was originally designed for this type of thing - it offers no distortion around the edges etc. A very nice lens.
  10. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Or a decent macro style ring light.
  11. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    This sounds like AutoCAD to me. Ask the client for a PDF or DWF file so you can print out. Taking a photo of the plans is a bad idea if your aim is for accuracy and quality. I work with AutoCAD daily and some of my project managers have attempted this method of taking a photo of the plan for me to draw. Needles to say I reject the project immediately. If it is a detailed set of plans, I'm afraid you will never take a photo and make it legible.
  12. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Getting the file will be your best bet. Most firms should have them and manufacturers should have them also. Takes a bit of calling around, but may be worth it. I sometimes just use a 60mm macro to shoot plans if exacting details are not needed. Mostly for permits and stuff where a general reference is only needed. Just make sure the piece is flat and lit consistently. Usually to clamp on lights at 45 degrees on either side.
