CCD cleaning
Discussion in 'Photography Beginners' Forum' started by akazoly, Jan 23, 2008.
  1. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Someone know which is the safest product to clean the CCD sensor? Thanks!
  2. Big Mike
    Dec 16, 2003
    33,853
    1,818
    Edmonton
    The Arctic Butterfly is a pretty safe product....but may have trouble with stuck on particles.
    With a bit of care and common sense...most sensor cleaning products are fairly safe.
  3. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I have a Nikon D40X SLR. I think my CDD has dust, please see this: http://home.wplink.net/~zoliky/dust.jpg
    Im very sad :( I need help, please!
    I don't have much money to spend on expensive cleaning solutions. I hear something about Eclipse and sensor swabs.
    1) Please check this for me : http://photosol.com/eclipse_e2product.htm my Nikon D40X appear at supported cammeras. Ok, eclipse E2 is good for me ?
    2) I need swab type 2 ?
    Big Mike please help me, thank you very much!
  4. Big Mike
    Dec 16, 2003
    33,853
    1,818
    Edmonton
    Firstly, just every DSLR will have dust on it, when tested. Even after cleaning, there will probably be a few spots. It's not a big deal and it's something that you just have to deal with when you have a DSLR. Don't be sad.
    E2 is a new cleaning fluid, especially for sensors that have tin oxide in the coating. I'm not sure if the D40 is one of those or not.
    Anyway, eclipse fluid and some sort of cleaning pad is a good way to clean your sensor. Look around, there are cheap kits and some that aren't so cheap.
    As for the swab type, I don't know. That shouldn't be too hard to research.
    A cheap method that I've heard...is to create something like the Arctic Butterfly...which is just a statically charged brush. You can get a small fan type paint brush, you can then use dry compressed air from a can, to blow on the brush, which should 'charge' the brush...then you use it to pick up the dust on the sensor. Be careful of the air you use...if it has any moisture or a propellant in it...that might get onto the brush and the sensor. Don't use the air directly on the camera.
    Cleaning aside, the dust marks usually only show up when using a small aperture...and even then, it's easy to clean them up with software.
  5. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I try to use air pump at 5 cm distance. But no luck.. I don't have courage to use the air pump closer.
    Thank you very much for help!
  6. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I see the dust on clear blue sky at maximum aperture: F3.5
    I think this is serious, I need a cleaning. What is your opinion ?
  7. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    If you can see it at f/3.5, yeah - I think you're way overdue for a cleaning. Are you sure it's not on the lens?
  8. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I read this on http://www.bythom.com/cleaning.htm "
    [FONT=Verdana, Arial, Helvetica, sans-serif]Unfortunately, Nikon began using Sony sensors that have a special coating on them (Indium Tin Oxide, or ITO for short). This additional coating is there to help the filter "shed" dust more easily (it essentially blocks some of the static charge that can build up and attract the dust). It is possible to damage this coating, and when you do so, the filter essentially needs to be replaced. Here's the list of cameras that do and don't have this coating:
    [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]ITO coating: D40, D40x, D70s, D80, D300, D2xs, D3[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]No coating: D1, D1h, D1x, D2h, D2hs, D2x, D50, D70, D100, D200[/FONT]
    Well, I need eclipse E2, right ?
    [FONT=Verdana, Arial, Helvetica, sans-serif][/FONT]
  9. Big Mike
    Dec 16, 2003
    33,853
    1,818
    Edmonton
    Yes, you should use the E2 fluid.
  10. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I try to use this fluid but I scare a bit.. I hear Tin Dioxid is very sensible.
  11. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Anyway.. Someone know how to put the D40X camera in cleaning mode ? I need to turn on the camera until cleaning finished? What exactly I need to do ?
    Thanks
  12. Big Mike
    Dec 16, 2003
    33,853
    1,818
    Edmonton
    Read the manual
clean ccd sensor greenville
does d3s have tinoxide ccd?
where to get my ccd cleaned in edmonton
