CF card question
Discussion in 'Photography Beginners' Forum' started by curious200, Nov 3, 2009.
  1. curious200
    curious200 TPF Noob!
    Nov 3, 2009
    california
    This may be a silly question, but is it ok to leave my camera on while I remove/put in the CF card or it that a bad idea?
  2. WimFoto
    WimFoto TPF Noob!
    Jan 18, 2005
    363
    chelsea, quebec
    they normally recommend turning of your camera, it'll likely say this in the camera's manual
  3. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    I think you're supposed to be able to hot-swap them, but I don't take the chance. It's easy to turn the camera off and on again.
  4. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    It's fine leaving the camera on. You just need to watch you don't remove the card while the camera is writing to the card.
    Most newer cameras have a warning though telling you it's still writing.
  5. o hey tyler
    o hey tyler Been spending a lot of time on here!
    Aug 3, 2009
    9,783
    2,722
    Maine
    As long as you don't take out the card while the CF Card Access light is on you should be good.
  6. ErectedGryphon
    ErectedGryphon TPF Noob!
    Sep 9, 2009
    333
    Houston, TX
    If you have a canon, the camera will shut off when you open the CF Card access port.
  7. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    I have 2 Canon cameras. Pre 40D I think the camera would lose any images in the buffer as soon as the door opened.
    My 40D and later cameras sound a warning and show a warning on the back. THe camera sdoes not shut down and will continue to write until the blinking light on the back goes out. Then you can remove with no loss of data.
  8. Brian L
    Brian L TPF Noob!
    Nov 4, 2007
    374
    Michigan
    I don't care if the camera shuts off when I open the door or anything else. My camera is off when switching lenses and cards. Think smart before getting into a bad habit and feeling you don't have to worry. That card is your film. Huh oh, when I open the door all these great pictures were erased. Not a good thing to get into. I say camera off. No matter what is a good way not to worry. Hope that helps.
