Changing Lens Mounts
Discussion in 'Beyond the Basics' started by Davey John, May 21, 2006.
  1. Davey John
    Davey John TPF Noob!
    May 21, 2006
    12
    Washington State
    I have a Nikon lens mount that I would like to convert to a Pentax lens mount. Is this something I can do myself or have it done at a camera store?
    Thanks
    John
  2. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,775
    50
    Ahwatukee, AZ
    I would strongly suggest you do that at a camera store. Here is, though, some idea of how it's done (excerpt from another post on a different forum):
    It might be possible to just remove the Nikon flange from the back of the lens and replace it with a Pentax flange; both are very simple parts and similar in general design. you could get a mounting flange off of a cheap K-mount teleconverter easily enough, and since the focus register of the Pentax is 1mm shorter than the Nikon, you shouldn't have any infinity-focus problems.
  3. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    There are adaptors on the market that allow you to change from one mount to another. My friend has a Nikon - Canon mount (it may be Canon - Nikon) but they are definitely out there.
    I think when you use one, you lose any features on the lens since it wasn't originally designed to "talk" to the camera it's on.
    Here's an example of what i mean
  4. chris
    chris No longer a newbie, moving up!
    Jun 20, 2003
    278
    25
    Scotland
    Try SRB (www.srbfilm.co.uk). They advertise a number of adaptors, Nikon to Pentax K is not on the current list but they will be able to advise if the lens can be modified.
    note that the Tamron lenses were designed to be used with adaptors; the lenses all had a common mount and you had to buy an appropriate adaptor to fit them to specific cameras. This made changing camera systems easy because you just bought new adaptors. Changing a lens with a dedicated mount can be much more complicated (and expensive) and usually involves loss of some lens functions such as the ability to focus at infinity, connection to the metering system etc.
  5. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,017
    494
    As far as I have figured out. So far there are only Nikon to Pentax screw mount adapters (m42). I have not found a Nikon to Pentax K or Pentax K to Nikon.
  6. Davey John
    May 21, 2006
    12
    Washington State
    Thanks for all your replies. This is an older Sears manual focus lense and the lense mount is for a Nikomat FT. The Pentax camera is a P3.
    John
can you switch a camera lens mount
change lens mount
change out lens mount
changing lens mount
changing lens mounts
diy camera lens changing mounts on tokina lens
how to replace a lens munt
