Cheap flash recommendation for D50
Discussion in 'Photography Equipment & Products' started by AluminumStudios, Jul 3, 2006.
  1. AluminumStudios
    AluminumStudios TPF Noob!
    Oct 20, 2005
    99
    Pennsylvania
    I did some forum searching and reading and everyone keeps talking about expensive Nikon flashes for use with a D50.
    I am on a tight buget and want to get a flash for my D50. It doesn't have to be anything fancy. I'd like to be able to use it on the hotshoe as well as have it work like a slave flash sitting elsewhere in the room (it will go off in response to detecting the light from my built-in flash.)
    I'm just a hobbyies looking for improvement over the built-in flash and I realizing that a <$100 isn't going to be as good as the Nikon flases people keep talking about, but I was wondering if someoen could make some suggestions since I'm a compelte flash n00b.
    I heard that some older flashes can cause voltage spikes that can hurt the D50's electronics too? Is that true?
    I don't mind learning how to use the flash in manual mode if it doesn't support i-TTL (I'm expecting any sub-$100 flash to not support many features.)
    Hell, if I could find a flash for $50 or less that gave me a little more than the built-in one (and has the ability to act as a slave) that would be fine.
    Thanks in advance!
  2. bigfatbadger
    bigfatbadger TPF Noob!
    Mar 19, 2006
    464
    Nottingham, UK
    I'm pretty sure no flash apart from the SB600 or 800 supports TTL on the D50. Older flashes like the SB24 can be picked up on ebay fairly cheap and are fairly good. I'm fairly sure it's alright with the D50, but you can't hold me responsible!!!!!!
    you might find
    http://strobist.blogspot.com/
    useful
  3. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Lol is there any resource that can tell you for sure which flashes are compatible? I imagine I'll be in this boat someday too as I'd like to have a flash but don't have a need for one that would justify big bucks.
    Maybe I just have to do some reading and research. :confused:
  4. AluminumStudios
    Oct 20, 2005
    99
    Pennsylvania
    I've been doing some searching and have yet to find some solid information. That's why I was hoping someone could simply point out some cheap flashes that would work.
    Maybe I'll have to start visiting camera shops and asking. Although you have to be careful of the chains because often the people working there don't know what they're talking about.
  5. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Exactly. I'll definitely want a flash but if there's any chance of it ruining the camera I think I'd need to be pretty sure of the answer. If I find anything I'll make sure I post.
  6. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
    yes, I am also searching for that elusive chart which lists every flash across the top and every camera down the side and tells me whether they work or not. Alas, it doesn;t seem to exist.
    I'm not writing it!
  7. alanH
    alanH TPF Noob!
    Apr 13, 2006
    25
    Yorkshire, England
  8. LWW
    LWW TPF Noob!
    Aug 3, 2005
    1,206
    Dayton,Ohio
    Read the D50 manual. I'm pretty sure it lists either the SB24 or SB25, maybe both, as compatible...but only in full manual mode.
    I'd wait a little longer and save up for the SB600 myself though.
    LWW
  9. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    You want a cheap flash, you use the Integrated. Otherwise, save up for an SB600.
  10. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
    What is this madness you speak of?
  11. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
    Right, it looks like any flash that is listed here:
    http://www.botzilla.com/photo/strobeVolts.html
    with a voltage of less than 12V is OK on a nikon DSLR. This is my reading into it, please inform me if I'm wrong and I will change this statement.
    If you want proper TTL metering, you have to get a sb600, ,800, metz 76 MZ5 (£500) or a metz 45 CL4 (£300), Sigma EF500 DG Super (£160) Sigma EF500 DG st (£99.99).
    I'd double check with a dealer on the sigma ones, Warehouse Express claims compatible with the D70 but doesn't mention the D50. This isn't an endorsement of any of the above flashes, just a list of those that are compatible. I'm sure there's more.
    hope this helps
    Jon
cheap flash for d50
cheap flash recommendation
cheapest flash for d50
flash recommendation cheap
how to use manual flash d50
usingh cheap flash on d50
