Choosing the right studio light setup
Discussion in 'Photography Beginners' Forum' started by Alarilue, Aug 12, 2017.
  1. Alarilue
    Alarilue TPF Noob!
    Aug 12, 2017
    5
    I ordered and have tested today for the first time!
    I ended up ordering a single 400W flash, this one su Fotocolombo.it
    with a 90x60 cm lightbox.
    I thought I'd try this solution to begin with because I am not sure I actually need two, and I can always add others gradually. The first photographer I worked with used only one flash and they were my favorite photos.
    Here is a photo from today's very quick experimenting. The set needs some work on the floor and I need to play with the position of the model and the intensity of the flash a bit more before it's absolutely perfect but I am very happy with what I got at the first try.
    You can see a bit of the set up, and the light quickly edited. I'm shooting in a mostly white and entirely dark room and I am aiming for a strong light/shadow contrast.
    Thank you for your support, look forwards to playing more!
    • Like Like x 2
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,262
    15,117
    USA
    It looks like you are off to a good start with your new lighting gear! One light CAN do a lot.
    One of the critical issues is how close, or how far away, the light box is from the model. From closer distances, there is a high level of light fall-off in intensity; as the light box is positioned farther away, the light will be more-even in its level of lighting, across the frame. In the 10-15 foot range of light-to-subject distances, the light is relatively easy to work with, without a "hot" side and a "dark side" to the frame.,
    Keep working on your setup and keep learning. Again, you have a good start here.
