Circular Polarized Filter
Discussion in 'Photography Equipment & Products' started by EleanorW, Aug 25, 2009.
  1. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Saskatoon, Saskatchewan
    Just bought my first filter today - before I open it, does anyone know if the Hoya Pro 1 Digital Filter is a good one?
  2. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    Simply: Yes.
  3. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Thanks Goontz - now I get to figure out how to use it :D
  4. CW Jones
    CW Jones TPF Noob!
    Feb 26, 2009
    813
    Connecticut
    put it on, point it at the sky at a group of clouds or something then rotate the CPL on the end and you will see the clouds get more defined and have more contrast. I LOVE my Tiffen CPL I haven't had a blown out sky in a while since I have been using it
  5. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Thank you CW
  6. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Ok so now I got to thinking.. do I keep that on my lens all the time?
  7. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    CW nailed it, as you spin the end you'll see the polarizing effect change so you can adjust how much affect it has.
    All the time? It's great for outdoor shooting, as the purpose is geared towards reflections caused by the sun; I wouldn't keep it on indoors or anything. It will help reduce haze, reflections [on non-metallic surfaces], and increase saturation of colors. That said, it's most effective when you're at a 90 degree angle to the sun (morning or evening, but not with the sun directly in front of or behind you).
  8. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Pretty much every nicely made antiglare coated filter is good. This is one of them. A bit expensive compared to the SHMC series from Hoya, but good none the less.
  10. CW Jones
    CW Jones TPF Noob!
    Feb 26, 2009
    813
    Connecticut
    Well... you could leave it on all the time, I just wouldn't recommend it. If you shoot inside or in low light you will find that the filter on the end will first off do nothing, it will actually just take some of the light up and could result in a lower shutter speed. However.... if all you do is shoot outdoors where there is plenty of light, no real harm in that!
    another good way to check out what the CPL does, aim your camera at the computer screen and turn it, you will see the screen get darker and darker then go black
  11. mariusz
    mariusz TPF Noob!
    Aug 20, 2009
    97
    Toronto
    I would recommed bw but hoya is not bad
  12. KmH
    Apr 9, 2009
    40,529
    5,540
    Iowa
    It is actually B+W, not bw.
    A CPL gives the most saturation and contrast when your lens axis is 90 degree's from the Sun. Straight overhead does not count.
    The CPL is most effective when the Sun is also no higher than 30 degrees above the horizon, while being 90 degeree's to eh lens axis.
    Control of reflections is a CPL's greatest benefit outside the above parameters. It will still give some saturation of the colors but not as much as during the first and last hours of the day.
