circular polarizer brands?
Discussion in 'Photography Beginners' Forum' started by thereforeiamx, Dec 14, 2008.
  1. thereforeiamx
    thereforeiamx TPF Noob!
    Aug 20, 2007
    134
    nyc<3
    Before I infest $100+ in a 77mm thin circular polarizer, which brand(s) would you recommend? I've mostly been looking into Hoya and B+W. but I hear sometimes that B+W supposedly makes their filters out of better glass/grades?
    What's your take on this?
  2. rubbertree
    rubbertree TPF Noob!
    Sep 7, 2007
    727
    Canada
    I use B&W
  3. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    B+W from what I have seen make a single line of top quality filters - Hoya make a range which goes from cheaper models all the way up to top line filters. Their bottom range are not too poor, but clearly not as good as their top range.
    So B+W offer top range only whilst Hoya give some budget line options.
  4. thereforeiamx
    Aug 20, 2007
    134
    nyc<3
    with the pains of not having a front thread, how would i protect the filter with it being on the camera? from what i hear from users, the plastic cap they supply does not hold well.
  5. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
  6. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    hmm is this for B+W only my Cirpol from Hoya has a front thread and mylens cap easily fits onto it without problems. Are you sure that it has no front thread
    Also I don't know how well filters stack with each other - I think you can get lens flare problems if you start stacking them.
  7. thereforeiamx
    Aug 20, 2007
    134
    nyc<3
    i'm simply worried about filter protection, not so much stacking since i'll rarely be doing any of it on a 10-20mm lens. :)
    of course the Kaeseman filters would have top of the line quality. you're paying that much for them. i was looking into these since my budget is limited:
    http://www.bhphotovideo.com/c/product/133012-REG/B_W_65016930_77_mm_Circular_Polarizer.html
    http://www.bhphotovideo.com/c/product/133003-REG/B_W_66026598_77_mm_Circular_Polarizer.html
    but wasn't sure if they were any different than Hoya filters in terms of grade.
  8. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    looking more at their range the two you are looking at there are the slimline versions - they make regular version in those grades which appear to have normal front threads and are a little cheaper as well. Glass quality I assume remains the same - simply that the slimline are thinner.
  9. tirediron
    Jul 8, 2005
    40,906
    12,421
    Victoria, BC
    B+W do indeed make two lines. They are both good, but the MC (Multi-coated) line adds extra coatings to even further reduce flare, CA, etc. They're pricey, but IMO, worth it.
  10. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    Before you invest alot in a CP for your 10-20, you should be aware that polarizers can act weird with ultrawide angle lenses. This is because the natural polarization of sunlight changes over the field-of-view of the lens. I have one for my 10-20, but find that I rarely use it. You also need to remember that you need a thin style filter (often more expensive) or you will get vignetting with the wide angle lens.
    http://www.luminous-landscape.com/tutorials/polarizers.shtml
