Circular Polarizing Filter
Discussion in 'Photography Beginners' Forum' started by lyonsroar, Sep 13, 2010.
  1. lyonsroar
    lyonsroar TPF Noob!
    Jul 7, 2010
    1,255
    99
    Omaha, NE
    I'm looking for a good filter and I found a couple, I was just wondering if there are any major differences between these two, besides the price tag. It will be going on my new Canon Eos XS. It seems one is a circular polarizing and one is just polarizing. What's the difference?
    [ame=http://www.amazon.com/HOYA-58CIR-Circular-Polarized-Filter/dp/B00006HOAQ/ref=sr_1_2?ie=UTF8&s=electronics&qid=1284398625&sr=8-2]Amazon.com: HOYA 58CIR 58mm Circular Polarized Filter: Electronics[/ame]
    [ame=http://www.amazon.com/Hoya-58POL-58mm-Polarized-Filter/dp/B000L9MGNE/ref=sr_1_8?ie=UTF8&s=electronics&qid=1284398625&sr=8-8]Amazon.com: Hoya 58POL 58mm Polarized Filter: Electronics[/ame]
    or could I just get this?
    [ame]http://www.amazon.com/Hoya-58mm-Introductory-Filter-Kit/dp/B000W3MPTO/ref=sr_1_4?ie=UTF8&s=electronics&qid=1284398625&sr=8-4[/ame]
    Thanks!
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    You will want a circular polarizer lens. The other type (linear) of polarizing lens will mess with the auto focus of your camera.
  3. lyonsroar
    lyonsroar TPF Noob!
    Jul 7, 2010
    1,255
    99
    Omaha, NE
    Good to know!
    Thanks for the quick reply. So I should spend the extra $$ and go with the Hoya as opposed to others?
  4. tirediron
    Jul 8, 2005
    40,925
    12,427
    Victoria, BC
    I would suggest none of those. Hoya and Tiffen are good, consumer-grade filters, but ensure that you the multi-coated verson; this is important to reduce flare, CA, and other undesirable elements. Since none of those expresly say 'multi-coated' I will assume that they're not.
  5. lyonsroar
    lyonsroar TPF Noob!
    Jul 7, 2010
    1,255
    99
    Omaha, NE
    [ame=http://www.amazon.com/Circular-Polarizing-Multi-Coated-Digital-Filter/dp/B0009K9PZ2/ref=sr_1_1?ie=UTF8&s=electronics&qid=1284399597&sr=8-1]Amazon.com: 52mm Circular Polarizing Multi-Coated Glass Pro 1 Digital Filter: Electronics[/ame]
    Like that?
  6. tirediron
    Jul 8, 2005
    40,925
    12,427
    Victoria, BC
    That's the one! :thumbup:
  7. lyonsroar
    lyonsroar TPF Noob!
    Jul 7, 2010
    1,255
    99
    Omaha, NE
    Now I'm not doubting you, but what really is the difference between that and a non multi coated one? I'm not a professional photog by any means, will I notice the difference to the tune of an extra $50?
    Thanks.
  8. myfotoguy
    myfotoguy TPF Noob!
    Feb 15, 2010
    855
    Minneapolis, MN, USA
    The difference with multi-coated is they are more resistant to flare. Some folks may never have to worry about that (if you never shoot toward the sun) and always have your lens hood (which I suggest doing anyway).
    I shoot toward the sun, so I wanted the multi-coated. Even if the sun is off to the side you may or may not run into an issue.
    Some info: MultiCoated Filters why they are worth the cost
    Hoya multi-coated are good filters. They are harder to clean than a B+W multi-coated (perosnal experience and from reading others comments on various forums). Although, the Hoya's are cheper than the B+W brand.
    If you can swing the extra cash, definitely go multi-coated, and B+W if you can swing it a little further.
  9. misstwinklytoes
    misstwinklytoes TPF Noob!
    Jun 13, 2010
    2,112
    40
    Texas
    I got a $20 one from adorama for my XS. It seems to work (for now) as I'm just learning when/where to use it anyway.
  10. Taylor510ce
    Taylor510ce TPF Noob!
    Jul 20, 2010
    702
    United States
  11. AgentDrex
    AgentDrex No longer a newbie, moving up!
    Jan 27, 2008
    2,837
    405
    Bemidji, Minnesota, USA
    Yes...I have a non-multi-coated Hoya Cir Pol, no hood and I shoot into the sun...I facetiously wonder where the glare comes from....but I like the glare...so there...is that fair...or rare...maybe its my artistic flair...okay I'll stop now...
  12. Scatterbrained
    Scatterbrained Been spending a lot of time on here!
    Apr 19, 2010
    2,184
    1,081
    Yucca Valley, Ca
    A few trips to the sperm bank and you should be able to get a B&W MRC Kaesemann Filter and call it a day. Just a thought, if you plan on upgrading your lenses you may want to get the filter that is appropriate for those lenses and then get a step up adapter rather than have to buy the same filter twice when you move up (most L zooms are 77mm for example, vs the common 58mm of the efs lenses).
