circular polfilter
Discussion in 'Beyond the Basics' started by spako, May 25, 2006.
  1. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    I have been reading about these filters here and I was wondering what their effect is, where you use it (indoor/outdor) and for what kind of shots...
    and I think you can rotate these filters on the lens, what is this for?
    any help would be very much appreciated!
  2. Philip Weir
    Philip Weir TPF Noob!
    Apr 29, 2006
    506
    Sydney, Australia. The land of peace and sunshine.
    Gooday [I'm Australian]
    Polarising filter, the most valuable and useable filter in the photographers kit. They can be used indoors or outdoors, but are probably more useful outdoors. I suppose in laymans language, they cut out reflection. They must be rotated to get the effect you want, but you can see though the lens on an SLR what you are getting. With an auto exposure camera, they will compensate for the density, though if you are setting the exposure manually, you should add about 1.5 stops. There is much more to say, but this should be sufficient for now. Philip.
    www.philipweirphotography.com
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    It makes skies and water look a lot better and helps with contrast, particularly on bright days when there's light being scattered.
    Rob
  4. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    I so miss my polariser, which I once lost in a wilderness and even a thorough search on the following day did not bring it back :(
    It intensifies colours, makes the sky look bluer, and if you photograph reflecting surfaces (water, shop windows, just to name two), you can, by turning the filter, block out the reflection and kind of "look through the water", while normally you would not be able to. With your camera, you will be able to see the effect while looking through the viewfinder and turning the filter.
    It is mostly used in outdoor photography on sunny days.
    The effects are minimized on overcast days when the light is very widely distributed by the cloud cover.
  5. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    Thank you so much for the help!
    I think I'll invest in one of those :)
  6. Richard Daley
    Richard Daley TPF Noob!
    May 25, 2006
    7
    Sedona
    By far the most popular filter used by professional nature photographers for all the reasons above. Also cuts out some haze in the mountains (BUT please don't let some sales person convince you to "always use a skylight filter" and then keep it on when you use your polarizer. Every piece of glass in front of the lens slightly degrades the image quality SO you should know exactly why you are better off with any filter. That said, I use a polarizer at least 85% of the time for my nature photography and recommend them to every student I have if they don't have one.
    From Sedona, good luck,
    Richard Daley
  7. PopPicker
    PopPicker TPF Noob!
    May 22, 2006
    43
    South East Australia
    As a note.
    Don't forget that auto-focus SLR's require circular polarisers so the the auto focus system doesn't get confused.
    A manual focus SLR can use either linear or cicular.
    With DLRS's it's best to consult the manual and see what they suggest as it varies i think.
    PP
  8. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Some zooms don't rotate the barrel and some do - that's the point which needs bearing in mind as you'll need a circular if the barrel rotates when zooming. Get a circular one, and you'll cover all the bases.
    Rob
  9. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    Thank you! I bought a circular filter :) now I can't wait for the weather to change so I can try it out!
  10. PopPicker
    PopPicker TPF Noob!
    May 22, 2006
    43
    Well well is THAT what it's about, I never ever bothered to find out. LOL
    Thanks Rob. :)
    PP
  11. Luke
    Luke TPF Noob!
    May 9, 2006
    159
    im not too sure, i wrote a short expose article about this a while ago, and im pretty sure you're wrong about the autofocus thing, thatll be a problem with any polarizer, if it turns, the light will change, autofocus problems have to do with the way the camera focusses, using a split beam system.
    http://www.deviantart.com/view/27094884/
