Cleaning a 20D
Discussion in 'Digital Discussion & Q&A' started by Scott WRG Editor, Mar 9, 2005.
  1. Scott WRG Editor
    Scott WRG Editor King of Smoothness
    Jun 21, 2004
    1,479
    16
    Haverhill, MA
    I was just curious as to how much it would/should cost to take my 20D to a camera shop and get it cleaned? I have some dust on the CCD (I probably shouldn't have stuck the camera out the hatch of a B-17 doing 150 mph :) and I don't want to screw it up by messing with it myself. Any ideas?
  2. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    I think in the UK its about £40? so it may be similar in the US....Ill have to get my stuff cleand to...damn mirror is weal dirty...ON BOTH OF EM!
  3. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    From what I been reading. Cleaning the sensor is part of the routine when you own a DSLR. It would cost you a fortune to have it professionally cleaned every time it needed it.
    There are special sensor cleaning pads available at camera stores and there are methods on how to do it...floating around the internet.
    Apparently it's not as risky as you might think. The sensor has a protective lens/coating over it...that's really what you are cleaning.
  4. SLOShooter
    SLOShooter TPF Noob!
    Dec 21, 2004
    421
    Be really really careful if you gonna clean the sensor yourself. It's like cleaning the shutter and you cna damage it really easily.
  5. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    Just wonder, what do your photos come out like when the sensor is dirty?
  6. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    From what I have been reading lately...it's not as easy to damage the sensor as people seem to think it is. It's like cleaning a small flat piece of glass. Shutters are far easier to damage because they are delicate.
    Of course care should be taken and common sense should be used.
  7. Rogue Monk
    Rogue Monk TPF Noob!
    Jan 18, 2005
    98
    Vancouver, Canada
    Meysha: it resembles small, out of focus, spots of dirt or squiggles (tiny hairs/fibers).
    The sensor is covered by one or more protective layers--either an anti-alias/high-pass filter or regular glass (similar to a lens).
    Though care should always be taken (and I won't be held responsible for you bunging up your camera), it isn't difficult to clean.
    Luminous-Landscape has a short tutorial on how to do it and Visible Dust is the recommended tools for cleaning both sensor and mirror chamber.
    Usually, even just a shot from canned air will knock it away (never shake the can or you could get spray and I don't usually use the supplied tube). I tip the camera forward in the hopes of the dust falling out. It isn't a perfect solution, but it works for most dust.
    One more thing...check the back element of your lens before doing any of this. I've found most of the major crud there first and have only cleaned my sensor twice since getting the camera.
  8. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    Let me just mention in this thread... I have recently learned, the hard way, to be really careful when cleaning the mirror or ground glass in an SLR. About a month ago I tried to clean the parts in my 20-year-old K1000, and eneded up temporarily making things significantly worse. Here's what happened... Since it's an old camera, the little foam that cushions the mirror as it swings up and hits the top of that chamer area was (and is) starting to deteriorate and come off, so some of it had already gotten on part of the mirror. It wasn't much of a problem since I couldn't see that area of the mirror through the viewfinder anyway, but I felt I should try to clean it off anyway. But when I tried to clean it off, I ended up smearing foam -- and the adhesive that is supposed to keep it in place on the top of the chamber -- onto the rest of the mirror. And then since the mirror is so close to the ground glass, I got some on it, too. It was quite nasty. Eventually, after a bit of work, I managed to fix it up so that the smearing is no longer noticable through the viewfinder, but it's still not perfect.
    Anyway, the lesson: be very, very careful when cleaning delicate parts of the camera, and make sure you take every precaution you can to avoid making things worse.
  9. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    You stuck it out a jet? That should be an interesting shot. Can we see?
  10. Scurra
    Scurra TPF Noob!
    Aug 19, 2004
    1,159
    7
    Kent UK
    If I get crud in my 20D I have a hurricane cleaner to get it out. Providing you don't do anything stupid like jam the tip onto the sensor it's quite simple to clean.
