Cleaning crud
Discussion in 'Beyond the Basics' started by Claff, Oct 19, 2006.
  1. Claff
    Claff TPF Noob!
    Aug 16, 2006
    179
    Waldorf, MD
    Shot a bunch of stuff today and noticed quite a bit of debris (for lack of a better word) in the results. I can see some crud on the mirror of my D100, just curious about what the recommended way to get rid of the crud without damaging equipment on the eve of a couple of big shooting days ahead of me. Does the D100 have the automagic de-dusting feature or do I need compressed air or a very gentle cloth or something completely different?
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    First of all...crud on the mirror will never show up in the images. The mirror flips up & out of the way when the shutter is tripped. Also, the mirror is quite delicate...so a little crud on the mirror is usually not worth the risk of possibly knocking it out of alignment.
    Second, are you getting 'dust on the sensor' spots? A Google search should show you some examples to compare to. If so, you will need to clean the sensor. This is pretty much routine maintenance for a DSLR...and no, the D100 does not have a de-dusting feature. (read the manual). It should have a sensor cleaning mode though.
    Google 'sensor cleaning'...or even try a search of these forums. There are different methods and products avaliable. Compresses air is not something you should use. Most canned air will leave a residue which you don't want on your sensor. Also, blowing that much air into the camera would probably just get dust everywhere.
