Cleaning Lenses and Filters -- How?
Discussion in 'Photography Beginners' Forum' started by astrostu, Dec 26, 2006.
  1. astrostu
    astrostu Guest
    So, I very accidentally got some grease on my new IR filter, and I don't know how to get it off without damaging the filter.
    So a basic question that I haven't seen answered on these forums before: What's an easy, non-destructive way to clean filters and lenses, and what are ways that are completely destructive (AKA, to be avoided)?
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Since you can't blow the grease off or brush it off, you need to apply something wet. Use lens cleaning solution and a CLEAN microfiber cloth.
  3. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    Anything which contains materials as hard or harder than glass is destructive. A piece of cloth with tiny bits of grit in the fibers will cause scratching.
    Lens tissue is a porous paper manufactured grit-free. It can be rubbed against glass without damaging the surface. Please note -- glass. That doesn't mean a coating on the glass. An uncoated filter or lens can be easily cleaned with a huff-and-puff to provide a bit of moisture followed by a rub with lens tissue.
    For coated surfaces, especially coated lenses manufactured in the 50's through 70's, a lens cleaning kit specific for photographic lenses is the way to go.
  4. Torus34
    Jan 26, 2006
    2,117
    37
    Dust can best be removed from a lens surface with a lens brush. Use the brush only for that purpose and keep it clean between usings.
    The microcloth and lens cleaning fluid are available at;
    http://www.surplusshed.com/
