cleaning the sensor
Discussion in 'Photography Beginners' Forum' started by Jaszek, Dec 2, 2008.
  1. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    Can I use pressurized air to clean my sensor? Not the one you buy in a can but with the machine that compresses air. I have one at work so I thought about taking my camera to work to blow the sensor. I have a rocket blower but it's the small one and I guess it doesn't blow enough air to get rid of the dust. If it wont work I'm thinking about buying this: http://www.bhphotovideo.com/c/produ...hic_Solutions_PT2C_SENSOR_SWAB_PLUS_TYPE.html
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    No.
    First, the pressure is probably way too high (typically 90-120 psi). Second, there could be water and oil in the compressor - you don't want that on your sensor.
  3. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I recommend this for sensor cleaning.
  4. Jaszek
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    Too bad I don't have a credit card to order this.
  5. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I'm sure B&H has something similar (I assume you were going to just go there?); the link you posted looks to be pretty much the same thing, less the 'spatula' (which you could probably make yourself if you had too).
  6. Jaszek
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
    the thing I posted is the acctual spatula with the "swab" with the cleaning agent at the end. So basicly almost the same thing you posted. I'll probobly go to B&H on thursday or friday.
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    There are several methods to cleaning your sensor and plenty of products to do so.
    The first step is usually a bulb blower...the 'Rocket' type are great. The next step might be a brush, something like the Arctic Butterfly from VisibleDust. Lastly, you can do a wet cleaning, which sounds like what you are talking about now.
