Clone Stamp Issues
Discussion in 'Photography Beginners' Forum' started by padrepaul77, Oct 3, 2009.
  1. padrepaul77
    padrepaul77 TPF Noob!
    Jan 28, 2009
    155
    Twin Cities, MN
    I tried using the clone stamp on the pictures and the people who fixed them on the forum knew what they were doing - I don't. I use clone stamp and go over the image but it does absolutely nothing. What am I doing wrong? Quite frustrating. I do the alt plus click and nothing changes?
  2. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    Padre,
    I don't remember the Windoze key strokes (I use a Mac). However, read the user manual or the help screens. It's a 2-step process. First, you identify where you want to clone FROM and then you identify where you want to clone TO.
    These locations are not absolute, they're relative. STRICTLY AS AN EXAMPLE, the FROM could be a half-inch to the left of the TO. After you do the FROM/TO the first time, each time you move the TO location, the FROM also moves. In thie example, the FROM will always be a half-inch to the left of the TO unless you consciously redo the FROM location.
    There is also a way for you to change the size of the clone and also whether the edge of the clone is hard or if it gradually decreases but let's leave that for later.
    Gee, I hope that made sense.
  3. padrepaul77
    Jan 28, 2009
    155
    Twin Cities, MN
    Hmm...well what I did was go over the are with "alt plus click" and then over there area again just clicking, and the results seemed better, but I'm still getting used to it.
    What I did was click first on the sky in the normal color, with alt, then clicked over the dust particle, and that seemed to do the job. I'll get the hang of this yet!
  4. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    Padre,
    A good way to experiment is to purposely clone the sky to something completely different, perhaps someone's face, so that the result of the cloning is very obvious. DON'T ACCIDENTALLY SAVE THE RESULT! Better yet, use a junk photo.
  5. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    for removing dust you are better using the healing brush
    Same concept, Sample (alt) from a smooth or an area with similar texture
    then click on the dust
    But in this case, you dont have to keep re-sampling as it always jumps back to the initial sample area, however if you wish to, you can re sample
  6. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    alt click only sets the area where you are cloning from... the normal clicks afterwards are whats pastes the new stuff...
  7. EhJsNe
    EhJsNe TPF Noob!
    Nov 23, 2008
    618
    A Riverside Town by Canada
    I thought it was ctrl click......
  8. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Think of it this way:
    "Alt-Click" is effectively "Copy" or "suck data from here"
    "Click" or "Mouse-down, drag, and mouse-up" is effectively "Paste" or "spit the data back out here"
    There is a small check box on the Clone Tool's toolbar labeled "Relative". If checked the position of the Alt-click copy location remains relative to the Click/paste location. When you make a second Click/paste without a new Alt-click copy/sampling the copy location simplys moves to maintain its position relative to the new Click location. If Relative is unchecked, the Alt-click/copy location remains fixed regardless of where subsequent Click/painting is done.
  9. Craig J
    Craig J TPF Noob!
    Aug 15, 2009
    75
    Fort Worth, TX
    Also, check the Opacity, and Brush size. They could be turned down. If your Opacity is turned down take it up to 100%, and try a brush size that is at 100 and it should work.
