Coding Help
Discussion in 'Off Topic Chat' started by oriecat, Mar 30, 2004.
  1. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Is The Support Forum gone? I can't find it... anyway... I am working on some webpages for work and I am wondering if something can be done...
    I am creating some indexes to our internal forms that we will be posting on our webspace. I will have 10 branch folders, but most of the indexes will be the same so I would like to just create one master and then upload it to each folder. But I would like it to show the name of the branch. Is there a way to have the page display a part of the full path name?
    For example: the path is www.cme.com/forms/location/index.htm
    Is there a way to have it pull the location out so I can put it in a header? Without having to just manually type the location in a header, which would mean I would need 10 separate index files...
    I hope this makes sense!
  2. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Have you used JavaScript?
    window.location.pathname
    gives you your page's path, I believe. If you need help, I'll check in later. Does your server support PHP?
  3. oriecat
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Thanks Mark. I don't really know anything about javascript, have only used a couple scripts that I have found and used as is...
    I did find the following script that pulls the full path and displays as links:
    Code:
    <script type="text/javascript">
    thePath = '';
    loc = '' +location.href;
    paths = loc.substring(7).split('/');
    file = loc.substring(0,6);
    for (i=0, n=paths.length;i<n;i++) {
      file += "/" + paths[i];
      thePath += '> <a href="' + file + '">' + paths[i] + '<\/a> ';
    document.write(' ' + thePath.substring(1));
    </script>
    but it's not exactly what I am looking for and I can't seem to tweak it...
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    When you say header, do you mean an <H> tag, or the title of the page?
    I can edit it later, but if you can run PHP, there's a nicer way to do it.
  5. Chase
    Chase I am now benign! Staff Member Supporting Member
    Mar 9, 2003
    7,809
    51
    Deep in the heart of Texas!
    TheSupportForum is temporarily missing (until I have some time to migrate it over to the new server :? ).
  6. oriecat
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Yes, an <h> tag (<h1 id="header"> to be exact!)
    Here's what it's doing now:
    http://www.moltenwords.net/cme/portland/
    I really want it to only say Portland instead of the whole thing...
    I think we can probably use php, altho not positive. I just don't know much about that either and am trying to keep the pages simple...
    Thanks again! :D
    Get working on it, Chase! Man, what a slacker... ;) (just living up to my title! Can't let ya down! :p )
  7. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Try this:
    Code:
    <center><h1>
    loc = location.href.split('/');
    header = loc[loc.length-1]
    if (header == 'index.htm' || header == 'index.html')
    	header = loc[loc.length-2]
    document.write(header);
    </script>
    </h1></center>
  8. oriecat
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Mark, I love you! Thank you so much!! :):):):)
  9. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    NP!
