color loss when scaning
Discussion in 'Beyond the Basics' started by Battou, Sep 23, 2007.
  1. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    I'm loosing color from picture to scan of the picture. The actual image has far better color and contrast but when I went to put it on to the computer via scaning I have lost a metric but ton of color and clarity.
    Is this due to scaning a glossy image? If so will printing it in a matte finish prevent this,or can the scanner settings be adjusted for better results?
    Is there a simple postpruduction procedure to correct this?
    Below is a cropped copy of the scan and a (sorry, not the greatest but...) picture of the original taken with my digital camera. The diffrence shows most predominately in the building in and of it self.
    [​IMG]
    [​IMG]
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    not really. The only way I've been able to get decent reproduction is to scan the negative.
  3. DPW2007
    DPW2007 TPF Noob!
    Sep 19, 2007
    404
    UK!
    I experience a similar problem myself. Only thing I have been able to do is up the saturation on editing software to make up for it.
    Still, hopefully I will be getting a proper negative scanner.
    David
  4. Battou
    May 10, 2007
    7,997
    26
    Can I do that or do I need a particular type of scanner?
  5. Jeff Colburn
    Jeff Colburn TPF Noob!
    Aug 6, 2007
    300
    Sedona, AZ
    Every image I've ever scanned, on every scanner I've ever had, has had this problem. Just open the image in a program like Photoshop or Photoshop Elements, and a couple of clicks will fix the problem. 90% of my images just need auto contrast and auto color.
    Have Fun,
    Jeff
  6. Battou
    May 10, 2007
    7,997
    26
    Thankfully My outdated software is not that out dated,lol. It dose have the auto contrast adjustment, I'll give it a try in a few.
    *EDIT*
    well, the shingles are still a little fuzzy but it got the color back
  7. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    I'm right there, word for word with Jeff. Consumer ($100-$200) scanners are more of 'all purpose' devices.
    There are several factors that influence the scanning info/process. No matter how "flat" you have your original, there is a certain amount of reflection/refraction that takes place. The scanning glass is not the best quality available. "Water clear" glass is too expensive for consumer grade devices.
    The best I've ever gotten from a scanner like this is about 90-95% of the original. Sounds like a lot but that 5-10% can be a real bugger.
  8. Battou
    May 10, 2007
    7,997
    26
    wow, I honestly thought this was a little more ioslated, I don't feel so stupid now.
  9. Jon, The Elder
    Jul 10, 2007
    376
    Nothing stupid about it at all. there is a lot more to scanning than many realize.
    Now, as to stupid..........
    Your family spreads around the fact that you can scan prints. Aunt Martha (your favorite) asks you to scan a shoebox full of old prints. You say "SURE" before you think of all the work involved. Now you understand the meaning of 'stupid', oh boy do you understand it !
    P.S. - now that you have gone this far, you might consider blowing out some of the phone lines......
  10. Battou
    May 10, 2007
    7,997
    26
    My aunt is old, It's likely that not only dose she have a shoe box full, It's prolly a very big shoe box, and not alone either. Then again, that'd be my luck.
  11. Deimodius
    Deimodius TPF Noob!
    Sep 27, 2007
    29
    Oakville, ON
  12. (Ghastly) Krueger
    (Ghastly) Krueger TPF Noob!
    Feb 20, 2006
    1,393
    Lost between tomorrow and yesterday
    You need a particular type of scanner. Some flatbed scanners have a device to hold and light the negatives (you can also use them in the regular way) and there are dedicated (more expensive, better results) negative scanners.
