color negative & photoshop
Discussion in 'Photography Beginners' Forum' started by soupman99, Jun 16, 2007.
  1. soupman99
    soupman99 TPF Noob!
    Jun 16, 2007
    4
    is there anyplace online that give instructions on how to convert a color negative to a positive? I've got a set of prints made from the negatives I have and I can't get my photoshop versions to look anything like what I got printed at the printer.
    I'm a graphic designer and am a pretty hardcore user of photoshop so if there's a way to do it, I'll be able to. I need someone to point me in the right direction.
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Image > Adjustments > Invert
    Then tweak the results.
    What you see on the computer will never be quite the same as what you get with a C-type print. Computers work in RGB whilst prints are CMYK.
  3. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    This is really interesting, I think.
    Perhaps it is a scanning issue.
    Could you post a faithful scan of the print and the negative?
    TIA,
    Lew
  4. soupman99
    soupman99 TPF Noob!
    Jun 16, 2007
    4
    The problem I'm having is that when I scan the negative it's so red that the red channel of the image is basically the only one that shows up. So I can't tweak the color channels without it looking SUPER grainy
    Here's the images that I've got.
    [​IMG]
  5. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    What's causing the problem is the masking layer in the film.
    You need to remove it.
    Try Image > Adjustments > Curves.
    Select the White Point eyedropper and click on the clear orange background.
    The cast should go and then do I > A > Invert and tweak it.
    Neg scanners usually come with driver software that removes this colour cast when you scan.
  6. soupman99
    soupman99 TPF Noob!
    Jun 16, 2007
    4
    I'm getting something that's pretty close. Any advice on getting rid of the grainyness and clearing up the quality aside from just the standard filters?
  7. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    The grain could be caused by not having a high enough resolution when scanning. Try upping it to the max then try Despeckle in Filters.
    Use the Curves dialogue to adjust contrast. Or levels.
    For final colour adjustments Image > Adjustments > Variations.
    Then use the Sharpen filter.
  8. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Why don't you just send them to a lab and get them scanned professionally.
  9. soupman99
    soupman99 TPF Noob!
    Jun 16, 2007
    4
    well...
    1) I don't wanna pay $10 when I might be able to do it myself.
    2) I'll get less of what I want and I'll have less control.
    3) I want to do it myself.
  10. The_Traveler
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    What scanner do you have?
  11. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    Lew is 110% right, your issue is with the scanner settings
  12. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    When you open your scanner software look for a dropdown box for settings, select color negative scanning if supported by the scanner, if its just a cheapo it may not have the option. H
