Hi. I currently am shooting with a Canon t3i and I'm looking to upgrade. I'm trying to decide between the Canon t5 and the t5i. Does anyone use these? Pros and cons?
The difference between T3i and T5i may or may not be significant. It depends on whether a new or improved feature is needed for you. And for sure I do not expect a big difference as far as image quality concern. If you are thinking about upgrading your camera, first let see if there is something you like to do or achieve but your current setup is the limitation.
There are chances that the issue maybe something else.
I have a T3 and am trying different modes and setting I have not tried before and am getting results far superior to my past efforts. Are you sure you need to upgrade?
A T5 would be a downgrade.
A T5i would be a very very slight upgrade. The sensor is largely the same, but the T5i has a slightly improved focus system and the articulated LCD is a capacitive touch screen. Don't look for much to change in the image quality department.
A T6i or T6s is a more significant general-purpose upgrade. It has a new sensor, higher resolution, and the "s" version has a second control dial on the back (a bit more like the mid-range and high end models.)
A 70D, 7D II, or 6D would be a more noticeable upgrade. But which of these offers the most improvement really depends on what sort of subjects you like to shoot. The 6D will have the best low light performance. The 7D II will have the best fast action performance and the best focus system. The 70D has a little of everything... a better focus system (but not nearly as good as the 7D II, but better than the 6D), better video capability, and fairly quick shooting speed (but not as fast as the original 7D nor the 7D II.) The 70D is the most affordable of the three.
I should not neglect to mention... often you'll get a much more noticeable improvement by upgrading lighting and lenses than you will get out of upgrading the body. Which lenses are you using and what are you shooting with them?
