Compatability
Discussion in 'Beyond the Basics' started by mister_henley, Jan 12, 2005.
  1. mister_henley
    mister_henley TPF Noob!
    Jan 12, 2005
    Cheshire, UK
    Does anyone know any compatibilty issues between an analogue flash gun and a digital camera - Fujifilm S7000.
    Urgent Help Required?!?!?! :( :?:
  2. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    what do you mean by analog flash?
    The fuji S7000 can use pretty much any non-dedicated shoe mount flash. it would probubly be better to use something newer then older, just because the trigger voltages used to be so much higher then they are now, but since there arnt any AF or other fancy contacts on the mount that might not even be an issue.
  3. mister_henley
    Jan 12, 2005
    Cheshire, UK
    Basically i have two flash guns used for old cameras which i presume are analogue. Just they don't seem to work with my S7000 which would be disappointing!
  4. malachite
    malachite Heavily Medicated For Your Protection
    Feb 23, 2004
    975
    6
    Not in Arizona anymore
    You'll more than likely just not have any TTL metering. New cameras and old flashes still work together just fine with the flash output being a completely manual operation. Worse case is that you have to mount the flash off-camera with a hot shoe and cord.
