Well depending on the lens itself odds are good your 50mm won't mount on a tc. Most short focal length lenses won'tIf I were to use a 2x convertor with my 50 mm prime lens. Would there be any issues or adjustmental I should be aware of?
I don't shoot pentax so can't be certain, but on the Nikon f mount the shorter focal length lenses the mount is not as deep as it is on the longer telephoto.Sorry Pentax K30 (k mount). Pentax site was confusing. Didn't specifically say you could just recommend not to go below 50.
Probably only once. The reason no one suggests such things because of their quality, or lack there of. For a P&S they often are the only option and there are some fairly decent ones as well as being costly, for the P&S. Again, they still are not made for short focal lengths. Best suggestion, save your money and get a good 100mm or a 70-200. You will get far more use with either than you will those.Maybe some of the others on here have seen these, but it's a first for me. Since they screw to the front there wouldn't be any compatibility issues. Left one is a 52 mm 2.2 x converter, Right is a macro adapter. As cheap as they are it's questionable how well they would work, but at less than $25 for both, might be fun to play with.
View attachment 119967 View attachment 119968
