concert lens
Discussion in 'Photography Beginners' Forum' started by pregnantcowlady, Feb 6, 2008.
  1. pregnantcowlady
    pregnantcowlady TPF Noob!
    Feb 4, 2008
    48
    in your opinion which would be the best lens for concerts?
    tamron 17-50mm f/2.8 or something like a 28 or 30 f/1.4?
    i need it to be fast, but the reason i want the 17-50 would be the versatility.
    i need the lens to also be wider and more easily used if i am 2 feet away from the stage.
    considering which one to buy.
    thanks for your help!
  2. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    The difference from F2.8 to F1.4 is two stops...so if your shutter speed with the F2.8 lens is 1/30...you could get 1/125 with an F1.4 lens. That would make a big difference when shooting a moving subject in a dark concert.
    That being said, you might find yourself rather limited with 28 or 30mm compared to the filed of view at 17mm.
  3. John_Olexa
    John_Olexa No longer a newbie, moving up!
    Feb 3, 2008
    436
    49
    Maryland
    Given those 2 choise's I would go with the tamron 17-50mm f/2.8 because of the 50mm.
    I work a lot of concerts from the foot of the stage And I use a 70mm !!2.8 lens 70 -200 zoom to be exact.
  4. pregnantcowlady
    Feb 4, 2008
    48
    well i already have a nifty 50.
    do you have any pictures of the concerts you've shot with the 70, john?
  5. AlexParlett
    AlexParlett TPF Noob!
    Jan 31, 2008
    49
    Oxford, UK
    Depends on the venue, and how the pit is placed.
    Usually have 20-40 f2.8 or a 30/50mm f1.8 and a 70-200 f2.8 or a 50-150 f2.8
    Mounted on seperate bodies, so i dont have to swap.
    Out of those two, the 17-50mm is better for versatility. SS shouldnt be a problem, with f2.8, just be mindful of the lighting, you might want to carry the 30 1.4 with you just incase tbh.
  6. pregnantcowlady
    Feb 4, 2008
    48
    so would it be wise to just take the 50 and buy a 70-200mm 2.8?
    i want to get one anyways.
  7. John_Olexa
    Feb 3, 2008
    436
    49
    Maryland
    Well thats's up to you. A Sigma 70- 200 is about $800.00. But you sure can't go wrong with it. It's my work horse lens.
    The reason I said to ues the 50 was it will bring the artist just that much closer to you. You can make up for the lost stop by bumping up the ISO.
    Heres 3 images I compressed then down in size to not take up a lot of room.
    all images copyright John Olexa
    Lee Ann Walmack
    [​IMG]
    Travis Tritt
    [​IMG]
    Willie ( no last name needed) ;)
    [​IMG]
