Continuous Lighting and Flashes, Which One Will You Choose?
Link Delight Online Shop
Official Vendor
Supporting Vendor
Continuous studio light is the light used by photographers for the purpose of having light continuously for the whole photo session that they take. It is such light that can be used for multiple purposes according to the ease of the photographer as it can be carried from one place to another. The bulbs that are fixed into such lights can be turned off and on and at the same time they also have a light stand or a tripod that can be very easily used by the photographer.
Flash speedlite is artificial light used in photography. When pressed the camera shutter, generally bettween 1/1000 to 1/200 seconds to illuminateb the scene. One obvious use of the flash is fill-in light for photography, taht is when insufficient natural light conditions for your subject artificially increase the intensity of illumination. Another use of the flash is lighting when shooting, and by arranging the position of the light, projection method (direct hit or jump flash, soft or hard light, whether beam) can increase or enhance the taste of photography quality photographs; multi-lamp collaboration and the use of off-camera flash is greatly enhanced creative of photographers. Again, with the help of high speed flash strobe, we can record object motion trajectory of a period of time, can provide scientific research to use.
Flash light, only at the moment of taking pictures can flash, but contionuous lights can last lighting. From the point of effect, continuous lights are usually better than the effect of the flash, so professional studio generally use this lights. At the time of video shooting, flash is completely useless, must use continuous lights. But continuous lights are large, trouble to use, basically need to decorate field beforehand. And flash is small and portable, and when not filming is low profile, so news photography and amateur photographers often use flash.
Different wattage size, contiounus lighting lights required must be sufficient, in which case the object will not appear much noise; flash light is in the time of flash release a lot of light. If you want to shoot still life, it is not too large. Contiounus lighting is better, almost like wattage, depending on your own situation. Anyway, should the latter, like shooting movie basically used contiounus lighting source. Photography are used flash light, the light is enough, and cover an samll area.
Continuous lighting: $b.jpg
flash speedlite: $j.jpg
