Controlling Built in flash with wireless SB900
Discussion in 'Beyond the Basics' started by spinxy, Oct 9, 2008.
  1. spinxy
    spinxy TPF Noob!
    Feb 10, 2008
    19
    Essex England
    Hi,
    when using the SB900 wirelessly my built in flash on the nikon D200 always over powers the SB900, how do i controll this?
    are their controls on the camera, or is there some sort of diffuser i need to use on my camera flash.
    or would it just be best to buy a seperate wireless trigger.
    also can someone suggest an unbrella stand which the SB900 will connect to.
    Thanks
  2. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    you can change your flash exposure in the camera... as for a umbrella stand.. any stand that has a hot shoe mount will work.
  3. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    I'm pretty sure your Nikon has "Commander" mode.
    Learn it, Use it.
    From what you've said, it would appear that you're using the 900 as a slave and the built-in as your primary. Which effectively means you have little or no control over either.
  4. K_Pugh
    K_Pugh No longer a newbie, moving up!
    Sep 26, 2005
    1,343
    75
    Scotland
    go into commander mode on the camera and turn the popup flash mode to "--".. better off not using it at all IMO. I'm guessing you know you can control the power of the SB from there, too.
  5. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    That totally depends on what he wants. Does he want no input from the on camera flash, use it as a fill or use it as the key light?
    Different settings for any of the 3 I listed above.
  7. spinxy
    spinxy TPF Noob!
    Feb 10, 2008
    19
    Essex England
    thanks everyone this threads been a massive help,
    it was already set to commander but built in was set to M
    aftr a little bit of fiddling around after reading this i have got the hang of controlling the built in flash.
    so wish i knew this 2 weeks ago!!!
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    Just in case you were wondering:
    M was for controlling the built-in light manually.
    TTL was for automated power level control of the built-in light
    -- was for triggering other remote flashes without the built-in light adding to the scene
    AA was for Auto Aperture, only available for the SB-800/900, not the built-in flash nor a SB-600 or SB-200.
how to turn of d90 built in flash and use sb900
how to use sb 900 as remote flash
how to use sb 900 wireless
how to use sb 900 without the built in flash
how to use sb900 as main flash on d90
sb 900 wireless
sb 900 wireless ttl
sb900 wireless
triggering sb-900 without built in flash
wireless sb900
