Conversion of 35mm focal lengths to Digital?
BernieSC
South Carolina
Website
www.bbrowderphoto.com
I am sure if I searched I would find this, but I thought this time I would be lazy. Does anyone know somewhere on this forum or the web that has a conversion chart, how a 35mm focal length would convert to digital format?
Thanks in advance.
Nikon uses a a CCD chip that is 2/3 the size of a 35mm negative. Therefore, if you muliply 1.5x the focal length of the lens you will get the adjusted focal length.
Eample: 18-70mm lens becomes 27-105mm on Nikon digital camera
Canon uses 1.6x for everything but the high end cameras. The 1Ds and 1Ds Mark II uses a full frame sensor. The 1D Mark II use the 1.3. I believe the older D30 and D60 both had the 1.6x sensor like the 10D, 20D and digital rebel.
