CP and Hood
Discussion in 'Photography Beginners' Forum' started by icassell, Jul 31, 2008.
  1. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    Dumb question --
    When I use a circular polarizer and have a lens hood on, it becomes a royal pain to spin the CP (especially with the deep hoods on my tele lenses). Does anyone have a method that works?
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Some hoods have a notch, to make it easier to rotate a filter. You could cut a notch in yours, but then you open up that area for the possibility of flare etc.
    You could use a screw in hood, that screws into the front of the filter.
    You could just abandon the hood and use your hand or something else to keep the sunlight off of the front of the lens.
  3. icassell
    Jun 7, 2008
    9,900
    15
    Arizona
    Hmmmm ... have never seen this kind ... might look for them. It's not an issue with my standard and UWA lenses, because the hoods are petal-type and pretty shallow. The hoods on my 50-150 and on my 100-300 are quite deep and I often use them with a CP.
  4. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    For examples of screw in lens hoods, see the following:
    http://www.bhphotovideo.com/c/shop/2226/35mm_Lens_Hoods_Generic_.html
  5. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I've got a couple of those folding rubber lens hoods. Just watch out that they don't vignette on your wider lenses.
    I typically haven't used a CP when using telephoto lenses. A CP can rob up to two stops of light, and I usually want or need that light more than I need the benefits of the CP.
  6. Nasir
    Nasir TPF Noob!
    Jul 24, 2008
    34
    Keep in mind though if you use a screw in hood, you probably won't be able to put on the lens cap without removing the hood. Just an added inconvenience that you might want to factor into your decision.
  7. icassell
    Jun 7, 2008
    9,900
    15
    Arizona
    Thanks all. I use my CP frequently. My 50-150 is an f2.8 and my 100-300 is an f4 so I'm often not too worried about the loss . I guess I had seen the rubber screw-ins in the wide-angle variety, but never had seen one for telephotos.
