CPL question
Discussion in 'Photography Beginners' Forum' started by sarasphotos, Aug 28, 2010.
  1. sarasphotos
    sarasphotos TPF Noob!
    Jun 19, 2010
    143
    usa
    I want a CPL but I am confused on the sizes. I know I need a 52mm for my 18-55mm and 55-200mm lens but what do I get for the 35mm f/1.8 lens? I cannot find it anywhere! Also is the CPL useful for portraits of people?
  2. invisible
    invisible Been spending a lot of time on here!
    Mar 10, 2007
    5,213
    977
    Canada
    If it's this Nikon lens, then you're lucky: it's also 52mm.
  3. sarasphotos
    Jun 19, 2010
    143
    usa
    it is the nikkon lens, sweet, thanks! :)
  4. sarasphotos
    Jun 19, 2010
    143
    usa
    also, is it good for portraits of people indoor and outdoor? or is it maily used for outdoor?
  5. invisible
    Mar 10, 2007
    5,213
    977
    Canada
    Of your lenses, I'd go with the shorter end of the 55-200mm for portraits. Your 35mm can reach a wider aperture and provide you with a much nicer bokeh, but you'd be too close to the model for comfort --plus their face/body might not look too natural if you have to get too close to them. The wide 35mm, however, gives you the option of shooting in close quarters, but of course that's probably not the setting you'd want to choose for portraits.
  6. sarasphotos
    Jun 19, 2010
    143
    usa
    I have the D3000 so the 35mm will actually be 50mm on my camera. What does the CPL do for portrats of people? Does it help the photo or not?
  7. KmH
    Apr 9, 2009
    39,216
    5,284
    Iowa
    For Nikon lenses, the filter size is noted right on the lens, usually the bottom near where it mounts to the camera, and it looks like: ø 52. The number is the filter size in mm, 52 mm in this case.
  8. sarasphotos
    Jun 19, 2010
    143
    usa
    thanks that makes it easy!!
  9. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    The CPL will do no more and no less for portraits than it will for any other type of shot. It's main purposes are to enhance color, primarily blues and greens, reduce glare / reflection from reflective surfaces and increase contrast, most notably in clouds. You will lose ~1.5 stops of light. It is a good tool to have in your bag. Don't cheap out, make sure it's multi-coated. Notable brands for the general shooter are B+W, Hoya and Tiffen.
  10. Nod
    Nod TPF Noob!
    Jun 6, 2010
    295
    10
    Illinois
    I would add that the CP works best at 90 degree angles from the sun. Also get in the habit of turning it counter- clockwise (from behind camera) so that you don't accidentaly unscrew it.
  11. KmH
    Apr 9, 2009
    39,216
    5,284
    Iowa
    To amplify that, a CPL works best when the lens axis is 90 to the Sun and the Sun is less than 30° above the horizon. A CPL doesn't work well when the Sun is directly overhead, which is also 90 to the lens axis.
    A CPL used for portraiture can make some people's skin look strange.
  12. Nod
    Nod TPF Noob!
    Jun 6, 2010
    295
    10
    Illinois
    Right you are KmH, I didn't word that right.
cpl for portraits
do i need cpl for portraits?
is cpl good for portrait
