CPL Vs Linear
Discussion in 'Photography Beginners' Forum' started by Ptyler22, Apr 13, 2009.
  1. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    I got a circular polarizer about a couple months ago but what I realized is that I will have to keep constantly adjusting it when I'm out shooting. So I won't be able to use my hood or just shoot shoot shoot, I will have to keep adjusting the filter for every shot. Do you have to do this with a Linear polarizer or is it always "on" and you don't have to turn it to adjust the polarization. Also do linear polarizers have a "stronger" effect than cpl's?
    I'm mostly going to be using it to shoot cars, so there will be lost of different angles and things that I have to adjust the cpl for.
    Thanks a lot!
  2. tsaraleksi
    tsaraleksi TPF Noob!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    The difference between a linear and a circ is that the circ won't screw up your camera's AF. Otherwise they behave the same with regards to the image. That you have to mess with the polarizer is simply an artifact of physics.
  3. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Go with Circ when in doubt, then it works with everything.
  4. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    if you want your hood on whilst shooting surf Ebay for some screwfit hoods. Then you can have the hood screw into the front thread of the circularpolarizer and have the best of both worlds. Vignetting (shadows in the corners) should not be a problem with these hoods on a crop sensor camera body and is most likley not a problem for fullframe ones either unless your using very wide angle lenses.
  5. Do'Urden's Eyes
    Do'Urden's Eyes TPF Noob!
    Apr 16, 2008
    881
    Mississauga, ON
    I've always been told because i shoot digitally i should use a circular, but linear is much cheaper, and if its only because of the auto focus that i need it i can just buy a linear and focus manually? Most of the time i use a polarizer i'll also focus manually.
  6. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Oh, ok, sounds like I've got the right one then, thanks guys!
  7. c0ps
    c0ps TPF Noob!
    Mar 16, 2009
    173
    Toronto, Ontario
    I'm not sure about this but Im gona throw it out here anyway. Why would you need a hood with a Circular filter on? the circular filter prevents glare off subjects and lens.
  8. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    but hoods also protect the lens against a lot of accidental bumps and scrapes. I really hate shooting macro without my lens hood on - so many twigs and such can end up comming into contact with the front element without you even noticing. Sure most of the time its fine - but there is going to be that one rose with that one really sharp thorn oneday!!
  9. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Ya exactly, I just want to protect it, I mean $350 lens, and then a $60 filter, I want to protect them plus flare off the lens from the sun still happens with the cpl on
  10. c0ps
    c0ps TPF Noob!
    Mar 16, 2009
    173
    Toronto, Ontario
    very good point lolI :,s
  11. dhilberg
    dhilberg TPF Noob!
    Jul 26, 2008
    516
    Washougal, WA
    It's not about shooting with digital equipment, it's about the AF and metering system in the camera. You can use either type of filter on your SLR, but any camera that has built-in AF and metering will most likely lose one or both of those features because of the way a linear polarizer manipulates the light.
    Here's some more in depth polarizer information:
    Polarizers
    Polarizer - Camerapedia.org
  12. EhJsNe
    EhJsNe TPF Noob!
    Nov 23, 2008
    618
    A Riverside Town by Canada
    Its the lens focusing and its rotating the filter.
    Get a lens with Internal Focusing and you wont need to reajust your filter.
cpl filter linear
cpl filter vs pl
cpl vs pl
difference pl cpl
filter pl vs cpl
linear polarizer stronger than circular
pl vs cpl
pl vs cpl filter
