Creating alternate depth perception
Discussion in 'Beyond the Basics' started by nowphoto, Nov 25, 2007.
  1. nowphoto
    nowphoto TPF Noob!
    Nov 25, 2007
    I've been asked to shoot a job where they are requesting that I make the distant landscapes appear closer than they are in relation to the foreground. What is the best way to go about this? and which lenses would you recommend?
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    you mean make the background look like it's close to the foreground? or in front of it? lol.
    If you want the first...
    Use the longest lens available to you. It's called lens compression.
    200mm makes things appear really close together.
    If you are meaning the second...then you must consult the creator of the universe...cause it's not possible.
  3. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    In theroy, pending subject, multiple shots at diffrent ranges and some photoshop layers may be capable of producing something to that effect...ish maybe.
  4. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
    What he said.
    The longer the focal length of the lens, the better.
