Critic My Photos?
Discussion in 'Photography Beginners' Forum' started by Nolan, Jun 5, 2009.
  1. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    TELL ME WHAT YOU THINK, LEAVE A REPLY
    So with your suggestions and comments from past threads in mind I ventured out into my local provincial park and took some shots that I quite liked. So can you comment on and suggest things about my photos? For more of my work go to, Optical Idea | My Life Captured
    Well here they are!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. William Petruzzo
    William Petruzzo TPF Noob!
    Aug 22, 2008
    635
    Washington DC
    I think you may have selected a few too many to get a really good critique on. It's also important to put spaces between them (it would also be helpful to number them).
    Overall, I think they look pretty good. Very crisp. The first ones appear to be a little bit overexposed. The composure on them looks pretty good. I think it would be a big improvement for you to use a more shallow depth of field and throw the background out of focus. Since the colors are so similar, the flowers in focus get lost in a sea of other flowers.
  3. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    Ok i will do as you suggested and edit the post.
    As for the comment/suggestion, thanks! I will be sure to keep that in mind next time i shoot!
  4. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    any one else got something to say?
  5. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    Over-exposed in 1 and 2, slightly in #3.
    DOF in all of them could be tweaked a little bit more to reduce it ever so slightly.
  6. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    All very valid points. I will be sure to use them next time i am out shooting.
    Thanks for the suggestions they are very appreciated considering I am only a amateur photographer.
  7. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    as are we all....
    I wouldn't even call myself an amateur photographer, just a dude with a camera.
  8. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    very well said, I agree!
  9. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    What kind of camera are you using to take these pictures with? No exif in any of the pictures. Looks like you're using a P&S camera.
    In your previous posts did you post flower pictures? Just wondering.
    Shooting in bright sunlight is a challenge and you normally don't want to shoot flowers in strong daylight. It's better to shoot flowers on overcast days. In bright sunlight all the colors gets washed out of the flowers. When it's overcast you get soft diffused light that doesn't wash out the colors.
    #1 - The flowers facing the sun are blown out. That new tree on the right is bothersome. It seems more like a snapshot than a photograph.
    #2 - The flowers facing the sun are blown out. The background is very busy and distracting. This one is also more of a snapshot than a photograph...almost no sense of composition.
    #3 - The flowers facing the sun are blown out. The background is very busy and distracting. This one is also more of a snapshot than a photograph...but this one had hope. If you could have shot this in a way to isolate just the two sets of flowers without a busy background it may have been interesting...almost like a mirror image type thing.
    #4 - The main flowers are getting lost in the busy background. Almost no sense of composition, just stuff spashed all over the place. The color in this one is better than the others.
    Next time...
    Watch your backgrounds.
    Get close to your subject, fill the frame.
    Watch the lighting. Be aware of where it's coming from and the kind of light you're shooting in.
    If shooting flowers, shoot them on an overcast day or take them into the shade.
    Your web page loads really slowly. I tried to check out the images but gave up after a few minutes.
  10. Baaaark
    Baaaark TPF Noob!
    May 27, 2009
    414
    North or South Pole... it depends
    Like everyone else said, your flowers are blown out :-( But I LIKE #4! The flower petals seem very... creamy and rich!
    You can try doing some spot metering with your camera by holding it in the right spot, then moving the camera with the shutter still half pressed. Either that, or manually go in and adjust the exposure compensation lower.
  11. Yes, definitely over-exposed.
    What matters more to me though is that the composition doesn't work perfectly. The backgrounds are very busy, and the subject gets a little lost in all of it. Two ways to solve that is to find a better angle, making sure the background is uncluttered. The other option is to use a "fast" lens with a wide open aperture. The faster the lens, the bigger the opening, which means a small number. Look for f/1.4, or f/2 or f/2.8. When you shoot "wide open" like that, the image will have a very shallow Depth of Field, meaning only a small portion is in focus. The background (and foreground, if available) will be out of focus, and the blossom would be sharp.
    Your camera was able to separate the subject from the background, it's pretty blurry already. That means pick simpler background.
  12. Andrew Sun
    Andrew Sun TPF Noob!
    Apr 22, 2009
    212
    Shot #3 is my favorite because you can see the visible mountain horizon (top right corner) which makes the flowers look really grand - almost giving it a new breath of air.
    Without that corner, it would not have been that good from my point of view.
