Critique Please
Discussion in 'Beyond the Basics' started by ckphotography, Mar 17, 2010.
  1. ckphotography
    ckphotography TPF Noob!
    Apr 20, 2009
    25
    Central MN
    I have just started to dive into high key photography. Having worked with mostly natural light this is a new adventure for me. I have a small space to work with (only about 14 feet long and 11 feet wide).
    I have two strobes on umbrellas set up aimed at the backdrop. I have a speedlight with umbrella set up as a fill light on the subject placed to my right (subjects left) with a white reflector to the right of the subject to bounce back light.
    Popped the white with curves and added a small amount of contrast. Viola! Ha- seriously- constructively critique. I don't quite like them.
    [​IMG][​IMG][​IMG][​IMG]
    [​IMG]
  2. KmH
    Apr 9, 2009
    40,353
    5,509
    Iowa
    Pretty good.
    A hair light and a kicker would help with subject definition as would nailing the background exposure in camera, rather than relying on Curves.
    Have you seen the tutorials by Zack Arias on doing high-key?
    The
    section:
    Is not a critique/gallery section of the forums. You could be limiting the critical critique's you might get by posting here, rather than one of the Gallery critique forums:
    As an example
  3. Garball
    Garball TPF Noob!
    Mar 17, 2010
    16
    Denver
    You shot yourself in the foot by over-lighting the background and under-lighting the subject. To compound matters - you then "kicked" it up in curves.
    Well, that strained all the pixels - and they're breathing pretty hard at this point.
    Now, establish a highlight on you victim - a real highlight. Then bring in you fill panel to compliment the main - we photograph with light and design with shadow.
    Now pop your strobes into the paper - just enough to achieve a white - carefully.
    If your goal is a true high key look then place your main almost in front and above you subject and use your fill panel from below chest high.
    g
  4. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    In high key mode I bounce 2 naked strobes off of foamcore on both sides of the seamless. I use 2 pieces of in front of the lens to bounce the light back. Creates a chaos of light with a limited "sweet spot" but I love it and use it often.
    Love & Bass
