That makes sense- thanks!denoise then sharpen, crop anytime
Seems logical!For me the last thing I do is sharpen no matter what editing I do,Especially if some noise reduction is needed I would not what to sharpen the noise then try to remove it later.I think everyone has there own work flow for what works best for them.
I suppose you can better see what 'final' impact your degree of sharpening will have to apply it post-crop. Yeah, I can see that.Crop then sharpen. IMHO, it's more efficient that way.
I suppose that's what I've traditionally done, but never really thought about the logic of things.image quality wise it does not matter. radius is variable by feature size, not total file size. I usually crop before I start anything, after I rotate and correct for perspective. but it does not matter.
I'm seeing a pattern here!If you crop first, then you have only the elements you want to in a photo to concentrate on with the rest of your post processing, which is probably less distracting and enabling more focus in what you want (pardon the pun)
Same here.I start my editing in my Raw converter (ACR) and one of my initial steps is global capture sharpening and doing global noise reduction.
I don't crop in ACR because I prefer the Crop tool in Photoshop.
But cropping is one of the first things I do I in Photoshop if I am going to crop.
In Photoshop after cropping I do whatever, if any, local sharpening I want done in the image.
I do a last global sharpening if the image is destined for print.
