Minimum 1600x1200 res for an 8x10. Resizing just depends on what your output size will be and if its for the web or print. I have an 8.2 MP camera and it has huge RAW files, so if I just need to print to a 5x7, I crop for a 5x7 and lower the resolution to 150 dpi in once click in Photoshop. Also depends if its BW or color for me.
now the difference between web and print would be...?
sometimes i go to the to the photolab and my pictures dont fit into an 8X10? is this because of there size? can i resize them and fix this problem?
All you need to do is to crop with a different ratio. If you have photoshop, you can set the crop tool to a pre-defined ratio.how would i go about messing with the aspect ratio?
