Cropping, Borders, Printing, and Framing
Discussion in 'Graphics Programs and Photo Gallery' started by columbus, Nov 29, 2009.
  1. columbus
    columbus TPF Noob!
    Feb 4, 2008
    59
    One of my friends wants me to make some prints for her so she can frame them. Many of the photos are cropped, so they are not standard dimensions. How would I go about putting a small white border around the photos and make a black background so they can be framed in say a 8x11 frame?
  2. jman6785
    jman6785 TPF Noob!
    Jun 18, 2008
    71
    Chicago, IL.
    re crop the photo if you can to the right dimension. i think 8x10 is more common then 8x11.
    if your cant re-crop without cutting off your subject then create a new document in Photoshop to the size you want the print to be. then add the photo of your subject to the new document, center it and merge the layers and save.
    hope this helps.
  3. KmH
    Apr 9, 2009
    40,746
    5,588
    Iowa
    Most labs register images to the center of the paper. So, if an image is cropped to something like 7.2 x 8.6, you can still get that printed on 8x10 paper. There will be white border around the image but it won't be even all the way around.
    Another way to go is to mat the prints with a custom sized window and frame at a standard size. In the case of the above example, 7.2 x 8.6, you could get a 9x12 mat with a 7.2 x 8.6 centered window cut in it so there would be 1.8 ' of mat on the short side and 3.4 inches of mat on the long side.
    Each custom cut mat would cost about $2 in the 8x10 size range. Check it out here: https://www.documounts.com//content/home
  4. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    You could...
    1) Get a custom frame (very expensive)
    2) Look on eBay to find a frame of unusual dimensions (you never know).
    3) mat it
    4) just print the photo on a sheet of paper of the right size for the selected frame and leave spacing
  5. KmH
    Apr 9, 2009
    40,746
    5,588
    Iowa
    They are only expensive if you can't put a frame kit together. Check out the same place I linked to above, but the frame section:
8x10 free borders for framing
printing photos with vintage borders framing
