cropping problem in PS :)
Discussion in 'Beyond the Basics' started by mentos_007, Feb 15, 2005.
  1. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,325
    102
    Poland, Sz-n
    hi! I've some trouble with photoshop. (I have 7.0 version)
    How to crop the picture and be sure that I constrain cropping proportions? I can easily do this with mask tool but not with cropping tool. and I dunno what to do with this. I'm sure there's such an option to constrain the photo proportions but I son't know where :)
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Use the rectangular marquee tool, and in its' options, the toolbar at the top, set it to fixed size, or fixed aspect ratio, and then select your desired crop. When you have it lined up, go to image / crop.
  3. Rogue Monk
    Rogue Monk TPF Noob!
    Jan 18, 2005
    98
    Vancouver, Canada
    You can also marquee around the entire image and then go Select>Transform Selection. This will give you the transform handles, but changes will only affect the marquee itself. Not the image.
    Then, hold shift while changing the selection, move it into place and hit enter/return. After that you can use the crop command.
  4. mentos_007
    Jun 29, 2004
    9,325
    102
    Poland, Sz-n
    ok thanks! I solved the problem somehow :) but it works now :)
