Cross-process portrait
Discussion in 'Alternative Techniques & Photo Gallery' started by fstop23, May 20, 2008.
  1. fstop23
    fstop23 TPF Noob!
    Jan 24, 2007
    112
    St. Petersburg, Fl
    Slide film processed c41. Only problem is that i have to print out digitally. When I scan in the negatives, it doesn't read the colors correctly, so alas, I have to photoshop. So until I can use an enlarger and print out w/ chemicals, the real colors will remain a mystery. Anyway, enjoy!
    [​IMG]
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    What do you mean it doesn't read the colors correctly? They're obviously not going to be normal colors if you've cross processed. And if your scanner is trying to correct the colors, you should be able to turn that function off.
  3. fstop23
    fstop23 TPF Noob!
    Jan 24, 2007
    112
    St. Petersburg, Fl
    i know the colors will be altered w/ the cross process...
    my scanner has always read negatives, images incorrectly, needing photoshop adjustment. I'm not sure if it is trying to color correct or not. I'll have to tinker with that sometime.
  4. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    It sounds like a problem with your software settings, then.
  5. nealjpage
    nealjpage multi format master in a film geek package
    Sep 16, 2005
    3,479
    Oregon
    Very nice pic! I love x-process, but I've never tried it with a portrait. Makes me want to try it.
  6. kaiy
    kaiy TPF Noob!
    Nov 27, 2007
    69
    Where do you get your film cross-processed and do they charge extra?
  7. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    ^^^^I wonder this as well, I really want to x-pro a roll
  8. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Generally, it is more expensive. For me, they charge 10 bucks extra, but that depends on the lab you go to. If you take it to Longs or something and ask them to process it, they shouldn't charge extra.
  9. fstop23
    fstop23 TPF Noob!
    Jan 24, 2007
    112
    St. Petersburg, Fl
    I took it to a local place in Erie, Pa to develop. I just told them to process it c-41, I didn't tell them it was slide film. So they didn't even know it was a cross process. If I were to develop it correctly, it probably would have been more.
  10. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Labs worry about chemical contamination as a result of cross-processing. So labs that do larger runs and thus work with larger volumes of chemicals therefore generally tend to worry less about contamination and charge less to cross-process.
  11. nealjpage
    Sep 16, 2005
    3,479
    Oregon
    And from what I've read, the chem contamination is an urban myth. But try telling that to a 16 year old kid behind the counter at Walgreen's. :lol:
best film in portraits cross processed
cross process in photoshop
cross process portrait
cross process portraits
cross processed film
cross processed portraits
cross processing for portraits
cross processing portraits photoshop 2012
portrait cross process
portrait cross processing
