Crosses and Couples
Discussion in 'The Black & White Gallery' started by kirif1, Mar 23, 2009.
  1. kirif1
    kirif1 TPF Noob!
    Mar 18, 2009
    88
    London
    I have recently started to take pics with the intention of turning them black and white. Here are my first attempts, any comments are gratefully welcomed :)
    [​IMG]
    [​IMG]
  2. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    #2 is very nice (although the tree (?) shadow in the very front is distracting -- looks like a finger almost). I like the interaction of the couple.
    #1 however has a lot going on. The crosses almost get lost against the bushes, tree, and bricks -- they're there but hard to see. You either need a shallower depth of field, or perhaps just recompose to put the crosses against a darker and less busy background.
  3. kirif1
    kirif1 TPF Noob!
    Mar 18, 2009
    88
    London
    Thanks for the comments, i'll have a play and see what i can do. the shadow in the front of no.2 is bushes (i was hiding in them :)) i considered cropping them out but wasn't sure, i might do so now and see how it looks.
  4. kirif1
    kirif1 TPF Noob!
    Mar 18, 2009
    88
    London
    Is this any better?
    [​IMG]
  5. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    The crosses are kind of better like this, but it also looks false... mostly so the halo around the near one.
    The couple photo is good! You can also clone out the shadow of the bush you were hiding in, I think. Though, if you cropped (but wanted to keep the usual print ratio of a photo), you might at the same time get rid of the tree trunk on the left...
  6. Rere
    Rere TPF Noob!
    Aug 10, 2008
    321
    In NC, but currently my husband and I are workcamp
    In the couple photo, the white burned-out leaves are distracting. And I'd like to see the couple lightened a bit. I'd also take out the tree on the left and clone some of the white blanket on the left. Really light areas lead the eye right to those areas.
    On the cross pictures, I like the second one better than the first. But if you re-shoot them, move a little to the left and try some other different angles.
  7. JE Kay
    JE Kay TPF Noob!
    Mar 12, 2009
    218
    SW Ontario
    Ya the crosses are nice. Did you hit that with some diffusion? Looks glowy..
  8. kirif1
    kirif1 TPF Noob!
    Mar 18, 2009
    88
    London
    I agree the crosses looks really fake now, the halo bit on the RH cross is actually a bit of light in that corner that came out like that once i turned into BW. I think i may have to retake that one :confused:
    As for the couple, i think i like the secluded feel you get from the slight tree frame, but agree with everything said :er: so, this is what i've done....better??
    [​IMG]
  9. teneighty23
    teneighty23 TPF Noob!
    Jan 6, 2009
    356
    Northern Alberta
    i actually completely disagree, i feel like the shadows in the photo make it much more of a secret or candid photo. slightly framing the subjects.
  10. Rere
    Rere TPF Noob!
    Aug 10, 2008
    321
    Ah yes, your couple picture, in my opinion, is much improved. However, I think that it depends on what you are trying to achieve with this photo. If it's for the couple, then they would prefer the second since it's a close up and you can see them better.
    If you are trying for an artsy look, then maybe you would want the couple back a bit as in the first---but with the tree and some of the blanket cloned out.
