CS4 Quick Mask Help
Discussion in 'Photography Beginners' Forum' started by burstintoflame81, Oct 16, 2009.
  1. burstintoflame81
    burstintoflame81 TPF Noob!
    Aug 7, 2009
    729
    Arizona
    Try as I may, I cannot seem to get Quick mask to work. I didn't change anything but when I click the button to enter quick mask ( so that I can see red on the covered areas and tweak them by painting white or black ) nothing happens. I do not see anything. I checked the options and Red is the chosen color. I cannot seem to figure out what is wrong and it is becoming very frustrating.
  2. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Do you have TeamViewer? if not, Get it and Ill watch your screen and try help you out.
    (its free)
    contact me via PM if you wish to do it.
  3. burstintoflame81
    Aug 7, 2009
    729
    Arizona
    Well, I figured out the problem, if anyone else has run into this. Its a glitch and can be fixed by setting preferences to the default. You do this by holding ctrl ALT and shift when starting cs4. It will prompt you to delete the old settings. This problem began after I changed a bunch of random settings. Most of which I can live with out if it means having my mask work.
  4. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    ooh thanks burst :) just learned a new trick :p not that Ill need it anytime soon... hopefully.
colorize a photo in cs4 with quick mask
cs4 quick mask not working
cs4 quick mask to find black
help with quick masks
quick mask cs4
quick mask help
quick mask will not work in cs4
tools quick maskcs4
