Custom White Balance?
Discussion in 'Beyond the Basics' started by ckphotography, Mar 4, 2010.
  1. ckphotography
    ckphotography TPF Noob!
    Apr 20, 2009
    25
    Central MN
    Hi Everyone,
    Just wondering if there are photographers who shoot weddings and take the time to custom white balance. If so, can you share your thoughts? How much time does it take? Do you use and white balance card? Are you happier with the quality of your photos?
    Thanks in advance for your replies!
  2. Big Mike
    Dec 16, 2003
    33,842
    1,815
    Edmonton
    I rarely set a custom WB, I shoot RAW and use AWB. If I need to adjust the WB in post, then I'll do that. Using Lightroom, I can easily set a consistent WB for a group of images with the Sync command.
    For something like a wedding, I'm not going to worry about a technically accurate WB. I'll adjust for what looks good.
  3. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    I am the opposite of Big Mike, I always set custom White Balance.
    It takes about 5 seconds to do using a Lastolite Gray Card, it is one less thing to do in post and saves time for me. If I need to tweak a few later I will, but most are fine this way.
  4. RONDAL
    RONDAL TPF Noob!
    Sep 8, 2008
    353
    The Great White North
    if you're shooting in the same conditions (ie lighting and location) and those conditions are constant over the length of your shoot, setting a custom WB makes sense.
    if not, you'll simply set for one condition and then it will be off when you move to the next. So you really have to be careful.
    I'd far rather prefer to just do it all in post, than worry about it in the field but to each his own
  5. Jeremy Z
    Jeremy Z No longer a newbie, moving up!
    Jan 4, 2007
    1,171
    31
    Chicago burbs
    With memory being as cheap as it is, your best bet is to shoot RAW and know you can always correct it later. Color correcting jpgs is no biggie either. RAW helps more in other areas, like tonal range, fixing too-dark shadows or too-light highlights.
  6. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    165
    San Diego, CA (RB)
    Custom WB.
  7. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    WhiBal. Quick, easy, flawless accuracy... Why not?
  8. Big Mike
    Dec 16, 2003
    33,842
    1,815
    Edmonton
    That may be true, but those are mainly exposure issues...and exposure is something that should be taken care of when you are shooting. Whether it's setting the exposure settings on camera or adjusting/adding light to the scene. RAW can help you 'fix' things, but it's better not to have anything to 'fix'.
    White Balance, on the other hand, is purely a digital setting. Setting it before or after, makes no difference to the final product. For me it's just a time and 'state of mind' issue. I don't want to take the time, or to even think about WB when I'm shooting a wedding.
    Now if it was a controlled photo shoot, I might be more inclined to set it in-camera. But still, I can set it and sync it in LR in less time that it takes to set a custom WB on the camera.
  9. Electricblue73
    Electricblue73 TPF Noob!
    Nov 15, 2009
    4
    Las Vegas, NV
    how do you set a custom WB if you are using an external Bounce flash on your camera? Is this a waste of time because you would be bouncing the flash from various surfaces/ceilings/walls, etc.... which would mean inconsistent size of light source ?
    I just started using an external bounce flash and wondered if setting the WB should be a priority before shooting. I use it mainly for shooting family pics inside the house, for now.
    I bounced the flash off walls and ceilings (side, behind, above,etc..) using a homemade bounce card attached to my flash.
  10. ckphotography
    Apr 20, 2009
    25
    Central MN
    Great replies everyone- Thanks! I'm gathering that it can be a personal preference thing and, having shot quite a few weddings, know that I am apt to forget that I set the custom white balance in one setting, move on to the next and have a very minor melt-down in the next setting when I'm trying to figure out why the photos are looking so awful. Until I remember, that is.....
  11. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    I set mine as well. You will need to reset or make a second preset for the reception indoors if that is the case.
  12. LearnMyShot
    LearnMyShot TPF Noob!
    Jan 8, 2010
    171
    USA
    I use AWB, but check as I go along....seems to work well for me!
custom white balance forums
setting white balance forums
