D300 and 18-200: DUST!!!
Discussion in 'Photography Equipment & Products' started by Val, Jan 30, 2008.
  1. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    Ive got D300 about 2 weeks ago. I made around 3500 shots. During that time i managed to get dust EVERYWHERE :x
    Camera:
    - viewfinder
    - BEHIND lcd glass
    Lens:
    - INSIDE on the second glass from top and on lower glass as well
    FFS this is supposed to be weather and dust proof :confused: and i did handle it with reasonable care. How am i supposed to get rid of it?
    PS forgot to mention - sensor is perfectly clean though :confused:
  2. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    Use a poofer.
  3. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    I had my D200 in the gnarliest of dust storms. After a good wipe down it was fine.
    Love & Bass
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Is there dust on the pictures or have any of your parts failed yet? No? There you go, weather and dust proof, which is exactly what it's meant to do.
    How did you get dust behind your LCD glass even with a protective cover on it... I've had my D200 for 1.5 years now and was snapping during dust storms twice and I've never gotten dust in there.
    Oh and the 18-200 is not a dust proof lens. Quite in the contrary it has rather poor build quality. But it doesn't matter so much. Unless the dust is really bad most of the light is scattered around it anyway.
  5. logan9967
    logan9967 TPF Noob!
    Jan 28, 2008
    611
    Philadelphia, Pennsylvania
    yeah dust behind the lcd doesn't sound right, i wonder if that is under warranty
  6. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    When i get back home (in about a month) ill vacum the camera and lens and report to you guys how it went :D
  7. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    You have taken a photo every 6 seconds for two weeks?
  8. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    No, i dont think so ;)
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Err. Be very very careful with the vacuum cleaner. It is highly NOT recommended to put a vacuum cleaner near the camera. Especially not on the back of lenses or inside the lens mounting.
    A blower bulb and brush should be your roughest attack on the dust.
  10. jedithebomber
    jedithebomber TPF Noob!
    Oct 3, 2007
    153
    Cottonwood, AZ
    Vacuum cleaners and electronic devices don't get along. Without a specialized vacuum the rushing air causes a buildup of static electricity. If you have dust between the lcd and the cover, see if there is a crack or separation somewhere where you get it repaired under waranty.
  11. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    :D actually i already vacuumed the lens pretty heavily ;) it didnt clear out all the dust but the lens works fine!
  12. Mike_E
    Jan 26, 2007
    5,327
    266
    The LCD cover pops off for cleaning on a D200 and most likely on the 300 as well. If there were dust behind the LCD you wouldn't be able to see it. Do use a blower (or a brush on things that won't scratch).
