D300 built-in flash never fires
Discussion in 'Photography Equipment & Products' started by notelliot, Jun 24, 2008.
  1. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    silliest problem ever. all i want to use it for is triggering SB-800s, but no matter what, the god damned thing never works. works on other D300s of course. anyway
    anyone else had this issue? just wanted to know if it wasn't an isolated issue before it goes to nikon for repair.
  2. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    Sorry if this is a silly question for you,
    But do you
    1) Have the camera in Comander Mode
    2) Have the onboard Flash turned off in the Flash Menu
  3. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    1. negatory
    2. negatory
  4. Kegger
    Kegger TPF Noob!
    Dec 30, 2007
    569
    The warm, sunny, very polite South
    Put the flash in commander mode. That should work.
  5. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Well honestly I think the whole system is pretty stupid because it just sems so unnecisarily complicated. I am sure there is some setting you are forgetting I would double check everything bfore sending anyhitng off anywhere.
  6. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Wouldn't make a difference.
    You can get to pop up, correct? It just doesn't fire.
    Check battery power.
    Reset to default settings.
    Test again.
  7. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    that's exactly my train of thought. i've reset it twice, tried with all kinds of settings changes and nothing works.
  8. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    1) It may just plain be broke
    2) Is the profanity necessary? I personally don't care one whit about it, but some people are personally offended by that particular phrase.
  9. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    Are you trying to trigger ther SB-800 Off Camera or when it is mounted to the hot shoe?
    If it is off camera you will need to be in comsnder mode and the flash will need to be set as well.
    One other question, will the flash fire then you are not trying to trigger the SB-800
  10. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    [​IMG]
    EDIT:
    Read it completely wrong the first time.
    Yes, you will need to select the Commander mode if doing off camera flash. Set Custom Setting Menu e3 to Commander mode. Built-in flash will funtion on any ( --, TTL, M), as will the Groups. Try everything set on TTL first.
    Make sure that the flash and camera are set to the same channel (I use 3) and same Group (A or B).
    Make sure the flash is set to Remote. (Hold center button down for ~3 seconds and move to the right block on top once in the menu).
    Make sure the built-in flash is up. You don't necessarily need line-of-site to fire the SB800, but do so in this testing. The receiver on the flash is beside the battery compartment, have it facing your camera.
    Check your batteries.
    Sorry about the first goof.
  11. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    it doesn't fire when i hide my sb-800s. obviously, it doesn't fire with an sb-800 in the shoe. doesn't fire when i stare into it. it's going to nikon.
    if you don't care, "one whit", why mention this? and as long as we're being picky, it was blasphemy, not profanity.
  12. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Just saying in passing, this is one reason why I chose to buy my bodies locally.
    Regardless, it's one of the seven words and there are people sensitive to blasphemy.
d300 buildin flash
d300 built in flash not working
d300 flash doesnt work
d300 inbuilt flash not firing
flash on my nikon d300s not working
how to fix nikon d300 built in flash
how to test nikon d300 built in flash
nikon d300 built in flash not working
nikon d300 flash not working
nikon d300 flash problem
