D300 Infrared White Balance?
Discussion in 'Beyond the Basics' started by skiboarder72, Apr 26, 2008.
  1. skiboarder72
    skiboarder72 No longer a newbie, moving up!
    Jan 17, 2005
    2,109
    78
    Greenville, SC
    I know this doesn't really apply to a ton of people but... Does anyone shoot Infrared on a D300... I'm having a tough time setting the custom white balance with an R72 IR filter on, anyone got any tips? I had no problem with my D50..
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Don't even bother. Shoot raw and set it in post. I have tried many times to get the white balance where I want it on the D200 but it's a non-destructive change in raw anyway. Plus not sure about the D300 but Lightroom and bridge have a larger range than the D200. The D200 goes to 2700K only IIRC. Lightroom goes down to 2000k
  3. 12321
    12321 TPF Noob!
    Mar 16, 2008
    50
    Adirondack Mountains
    I don't believe its possible with the d300 man, looked it up in some blogs and all those bloggists say its impossible, you'd have to change some internals of teh d300...
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  5. skiboarder72
    Jan 17, 2005
    2,109
    78
    Greenville, SC
    Does the nikon capture software let you adjust it this low... I can never get it into the infrared range with software... 2000k usually still looks redish/pink
    If thats true that sucks... good thing I still have my D50 :)
    I'll have to look at his exif data when I get home... but he says he shot them with filters... there's gotta be a way to set a custom white balance that it doesnt reject... grrr
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    I am not sure. In reality it doesn't matter. If you export from capture into photoshop keeping the file as 16bit then regardless of what your RAW converter's limitations are the white balance can be adjusted in the editor.
    Don't let the white balance scare you off [​IMG] Didn't even change the white balance before importing that into photoshop to make some edits.
    As an afterthought too try setting a manual white balance target image with the D300. If it's anything like the Canon EOS cameras then this manual white balance allows the camera to go much cooler than the settings themsevles would normally allow. Never tried this on mine though because as I said before I do this in post processing anyway.
  7. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    Don't most IR photographers white balance on something green with the filter off?
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  9. frXnz kafka
    Jul 9, 2007
    517
    Maine
    You're right. White balance off something green (grass, leaves) with the filter on.
  10. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    An engineer or someone who writes the marketing material and is easily reachable via phone? Coming from a background of forcing stupid marketers to put me through to an engineer of say a small circuit, the story changes quite a lot.
    And in any event. Proof is above. AND they said it about the D200 too. Counterproof to that one is in my gallery.
  12. skiboarder72
    Jan 17, 2005
    2,109
    78
    Greenville, SC
    thanks garbz i'll have to mess around with that this weekend
custom white balance with nikon d300
d300 infrared
d300 infrared photography
d300 ir
d300 ir white balance
infrared photography white balance nikon d300
infrared white balance
nikon d300 infrared white balance
photography balance
setting nikon d300 ir
