D300 settings question?
Discussion in 'Photography Equipment & Products' started by mcoppadge, Jul 6, 2009.
  1. mcoppadge
    mcoppadge TPF Noob!
    Nov 20, 2005
    240
    Pennsylvania
    I often shoot manually. I've become very annoyed that I can change the shutting and aperture settings, snap a shot, then when I take my finger off the shutter button the camera changes the settings I just set. Is this an automatic operation that I can just turn off somewhere on the camera?
  2. smadab
    smadab TPF Noob!
    Jul 1, 2009
    12
    Atlanta, GA
    Well there are a plethora of custom settings related to metering and function assignment. I'm not sure what you mean though - how is the camera changing your settings in manual mode? Which settings are being modified?
  3. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Are you absolutely sure you're in the Manual Shooting Mode? Take you right index finger and press down on the Mode button (same as if you are formatting your memory card) and with your thumb, turn the command dial to "M" (displayed in the top LCD). If that is the case, then there might be a fault because your settings should not change unless you change them.
  4. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    X2
    Maybe your camera is possessed?
    The only thing I can think of is that you may be shooting in P not M.
  5. mcoppadge
    mcoppadge TPF Noob!
    Nov 20, 2005
    240
    Pennsylvania
    It's definitely Manual.
    The only settings that change are shutter speed and aperture. Sometimes, not always. It's a pain because I'm constantly having to remember the previous settings of the last shot I took if I need to tweak them from where they were. If I have it set at 1/200 f/2.8 and take a shot at those settings, when I let go of the shutter button the camera may set itself at 1/400 f/2.8 or 1/125 f/3.5, etc.
    I still use autofocus, so that part isn't manual, but it shouldn't affect those settings, should it?
  6. smadab
    smadab TPF Noob!
    Jul 1, 2009
    12
    Atlanta, GA
    Ah, I bet you have Bracketing on. Press the Fn button and rotate the main command dial until you see 0F 0.3 in the Control panel and/or the +/- icon disappears from your viewfinder.
  7. mcoppadge
    mcoppadge TPF Noob!
    Nov 20, 2005
    240
    Pennsylvania
    Bingo. Thanks! :thumbup:
chamge apeture setting d300
d300 settings
d300 settings forums
