D3100 flash issue
Discussion in 'Digital Discussion & Q&A' started by purple_heyze, Aug 9, 2011.
  1. purple_heyze
    purple_heyze TPF Noob!
    Aug 9, 2011
    Hi Guys,
    I’ve been using D3100 since sometime now. Today I clicked few snaps using flash & everything worked fine. After that I spent some time exploring menu set-up options and played with few settings. Since then I have observed that my flash isn’t working. It pops-up properly under low light but doesnt produce any flash light. I went to menu set-up and reset all the options but still flash doesn’t flashes at all. However, it pops up properly. Any suggestion on if I need to do anything or is going to service center is the only option now?
    Thanks,
    Varun
  2. Ant
    Ant TPF Noob!
    Jun 2, 2004
    438
    Luton. UK.
    Try this: Turn the camera to 'AUTO' then press the flash selection button (the top one on the front left hand side of the camera as it faces away from you) keep it pressed down and turn the thumb wheel until the flash mode on the rear LCD says auto. then make sure the lighting is dark or subdued...There will be a little flash icon in the far right lower corner of the viewfinder...and take a picture. The flash should operate. If it doesn't then. unfortunately there';s a fault on your camera.
d3100 flash not working
d3100 is in flash mode camera not working why
how to fix d 3100 built in flash
nikon 3100d flash was not working
nikon d3100 built in flash not work
nikon d3100 flash faults
nikon d3100 flash not working
nikon d3100 flash pop up wont work
nikon d3100 flash wont work
nikon d3100 stuck in flash mode
