d40 cls combatible?
Discussion in 'Photography Beginners' Forum' started by brendan222, May 4, 2008.
  1. brendan222
    brendan222 TPF Noob!
    May 4, 2008
    hi i was just wondering if the d40 supports the cls, which can wirelessley operate the sb 600 and sb 800
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    Yes it's CLS compatible, but no it doesn't have the commander mode built into the camera. You need either an SB-800 flash or the SU-800 commander to operate remote flashes wirelessly on everything from the D60 on down. The D70/80 on up have the commander mode built-in.
  3. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    Yep, you'll need some sort of commander for the D40 (I think there's only the SU-800 or the SB-800 flash) to work with the Creative Lighting System. However, flash synchronisation cables work just as well, and are much cheaper. I've got a basic SC-28 in the post, and I can't wait to explore the new possibilities.
  4. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    Yep, these guys are correct. I have a D40 and SB600. When the SB600 is connected to the camera (either hotshoe or by the SC-28 cable) you get full CLS. Plus the D40 is nice because you get the very fast 1/500 sec shutter speed, very handy for adding fill light in bright sunlight.
  5. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
  6. TamiyaGuy
    Jun 25, 2007
    1,078
    Chelmsford, UK
  7. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    Also the SC-28 gives you full CLS and iTTL, those Cactus triggers don't.
  8. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    What generates the commander signal when you do this? My understanding was that your explanation is correct IF you're using the SB800 but it won't work with the SB600.
  9. ScottS
    ScottS TPF Noob!
    May 14, 2007
    2,334
    Denver, Colorado
    The 800 is the only one that can work as a commander. The 600 is a slave to the 800.
    Andrew was not correct.
  10. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    That's what I had thought.
  11. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    No, I said when the SB600 is connected via the cable or mounted on the camera, then it will work with CLS, which is how I am using my SB600. There is no comander signal when using the cable and you cannot trigger other flashes, which I think is where the confusion is.
    Maybe I should not use the term CLS in this case, since there is no wireless communication going on. I meant CLS in the sense of automatic metering where the camera sets the flash power level.
  12. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,696
    64
    Missouri
    Exactly... but beginners please note that andrew is specifically talking about the D40 and not the D40x. The "X" has a lower flash sync speed than its older and cheaper brother.
cls d40
d40 cls
d40 cls commander
d40 compatible with cls
is d40 cls compatibel
is the d-40 cls compatible/
is the nikon d40 compatible with cls
nikon cls d40
nikon d40 cls
nikon d40 cls compatible
