D40 vs. D70
Discussion in 'Digital Discussion & Q&A' started by jonahr, Aug 25, 2008.
  1. jonahr
    jonahr TPF Noob!
    May 31, 2008
    55
    I am interested in purchasing my first dslr, and i am seriously considering either the d40 or the d70, other than the obvious difference in size and age, are their any differences in features between the two?
  2. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
  3. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    The D70 has a focusing motor, making compatiable with all af lenses, the d40 requires AFS lenses for autofocus, which are less common and more expensive.
    The D70 has a more convienent button layout and requires less menu-digging to change common options.
    The D40 has a MUCH larger screen
    The D40 has a larger memory buffer, allowing it to take more pictures without a pause.
    The D70's battery life is forever and a day, the d40 doesn't last as long--probably due to the larger screen.
    D70 uses compact flash, the d40 uses sd
    Picture quality is nearly identical.
    The D70 cost about $350 used, the D40 goes for about $250 used.
    Overall they are both good cameras, I prefer the D70 due to it's size and button layout, and autofocus motor.
