The entire image looks overexposed. You may have Exposure Compensation set incorrectly. See page 70 of your manual.
Thanks, checked and Exposure Compensation was set at "zero" , and I understand that is disconnected when in "auto" mode
Don't shoot at auto? Seriously, it's a waste of money otherwise.
Sparky, is it even possible to set exposure compensation in full auto mode on Nikon? As far as I know, it isn't possible on my Canon....
Sparky, I know how EC works, I don't need an explanation... I just don't know if it's possible with Nikon, because it isn't with my Canon. When I select Full auto mode, I can't change EC at all. Understand?
Tomasko said:Sparky, I know how EC works, I don't need an explanation... I just don't know if it's possible with Nikon, because it isn't with my Canon. When I select Full auto mode, I can't change EC at all. Understand?
You can't change the EC when shooting full auto with the d5100
Auto correct didn't do a very good job. That grass looks positively radioactive; where was this taken, Chernobyl?!
What did you meter on? In other words, what was the focus point pointed at when you pressed the shutter half-way? I suspect it may have been on the black wall of the building which is why everything else is blown to oblivion.
Can you change the metering mode in Auto? If so, set it to "Matrix" (see your manual) which will give you a more even exposure.
Or, you could try putting it in "P" mode, which is similar to Auto, except you can control the exposure compensation.
Did you by any chance have a filter on your lens?? Do ALL your pictures look like this or is this just a one time thing?
The problem might be the crystal clear daylight condition. There are a few spots (sky and white in front of building) that are completely blown out. Maybe (and I say maybe cus I am a noob) it is due to the sun. Direct sunlight isn't your friend! Shooting on auto will not always get you a correct exposure!
I recommend learning how to use manual, aperture, and shutter mode. Aperture and shutter are pretty easy to figure out. If you always use auto - then you basically bought a really expensive point and shoot camera. I'd also read the manual a few times since there are alot of different things that can affect your picture. The full manual (200+ pages) probably came on a CD with the D5100.
This thread is the 47th reason I never shoot in auto.
I have a UV filter on the lens, think I will have to "play " with different settings in the P mode
