D60 pics - Noisy
Discussion in 'Photography Beginners' Forum' started by pongerts, Aug 28, 2008.
  1. pongerts
    pongerts TPF Noob!
    Jul 24, 2008
    89
    AUH, UAE
    ei guys...i just got my cam and i've got a question.
    i always find my pictures to be noisy. look at the black areas of this pic. It has lots of noise. what should i do? do i have a faulty cam?
    [​IMG]
  2. AverageJoe
    AverageJoe TPF Noob!
    Sep 16, 2007
    918
    4
    Minneapolis, MN
    Can you provide the technical specs behind this exposure? In windows, right click on the file, then click on Properties, then click on the Summary tab then click the Advanced button and tell us what the ISO was set at.
    I'm not familar with Nikon but you could try locking the ISO at 400 or lower.
  3. rotchcrocket04
    rotchcrocket04 TPF Noob!
    Aug 12, 2008
    15
    NorthEast US
    I would imagine it's because of the ISO setting. Like AverageJoe stated, find the ISO setting and let us know.
    My D40 does a pretty good job even with the ISO on auto, I rarely get any excess noise in the darker areas. This is with average/good lighting of course... I not talking about night shots though.
  4. toofpaste
    toofpaste TPF Noob!
    Jul 11, 2008
    1,202
    Earth
    Dude....that picture....seriously.... Funniest picture ever.... ehm...er
    but yeah. Try ISO
  5. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    The iso is set at 400. Try some shots at 100 and see if that is an improvement. I don't find the noise to be too bothersome though.
  6. K_Pugh
    K_Pugh No longer a newbie, moving up!
    Sep 26, 2005
    1,343
    75
    Scotland
    Doesn't look too bad, may be more noticeable 100% though. What sort of PP have you done, if any?
  7. Village Idiot
    Mar 20, 2008
    7,274
    406
    Also, it looks under exposed. What mode are you using? If you're using Auto, then bump up the metering to over expose by 1/3 - 2/3 of a stop. Under exposed photos can show noise regardless of what ISO you're shooting at, especially on some cameras.
  8. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    :) Looks like you guys are having fun cooking :)
    Here are the info I found from the picture. (From Firefox EXIF viewer addon)
    Camera Make: NIKON CORPORATION
    Camera Model: NIKON D60
    Image Date: 2008:08:27 23:38:08
    Flash Used: Yes (Manual, return light detected)
    Focal Length: 48.0mm (35mm equivalent: 72mm)
    Exposure Time: 0.017 s (1/60)
    Aperture: f/5.6
    ISO equiv: 400
    White Balance: Manual
    Light Source: Flash
    Metering Mode: Center Weight
    Exposure: aperture priority (semi-auto)
    ISO 400. Yes, you can lower the ISO but may need to lower the Aperture setting (wider aperture) if possible (like f/4). Or you may need to increase the exposure time but that may run into problem if you are not using tripod or your lens to not have VR, especially this picture was already taken with 72mm focal length and 1/60 shutter speed.
  9. pongerts
    pongerts TPF Noob!
    Jul 24, 2008
    89
    AUH, UAE
    thanks for the input guys.
    i did use a tripod with this shot because, i'm in the picture too. :)
    there i also used a flash unit to bounce the light (i guess the angle was a bit off).
    no PP was done on this image.
    maybe i just need to get more practice.
    thanks for the help guys...
    i do hope i get to learn how to shoot 'nearly' like a pro!
    thanks again guys!
  10. Village Idiot
    Mar 20, 2008
    7,274
    406
    If you're using the flash (assuming it's an SU or SB unit with TTL), use manual. shutter speed 1/200 set your apeture appropriately...f/5.6-f/9 for a group shot maybe, your ISO to 200, and shoot. If it's dark, bump up the flash exposure compensation (FEC on Canon's flashes) by 1/3 of a stop until it's bright enough. Bounced usually gets +1 - +1 2/3 from me depending on ceiling height. That's usually what it takes in a house with standard ceiling heights.
  11. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    If you're pixel hunting, you're going to find noise, period. If you want noiseless results at high ISOs, you need to spend thousands of dollars on high-end Nikon bodies.
    But, really, the noise in that picture isn't bad at all. Do you have a flash? Apparently, the SB400 is quite good and can be bounced off the ceiling to create a natural-looking light. You could do that and lower the ISO to reduce noise.
  12. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    Also, you may also try using the noise reduction software and see if that give you a better result for the same photo. (i.e. Noise Ninja)
d60 settings to minimize noise
how do i reduce noise d60
how to reduce noise nikon d60
how to reduce the noise on my d60
nikon d60 how to eliminate noise in your pictures
nikon d60 reduce noise
noisy photos d60
reduce noise in d60
why my d60 photos are noisy
